29588 Discussions
problem with compiling a 32bit executable file
Emily_Y_
Hi,all
I am a beginner on this and I need to compile a f90 file. The executable file is 64 bit by default. Is there any way or any options to compile a 32bit executable file? I am trying to compile in ia32, using "source /opt/intel/Compiler/11.1/059/bin/ifortvars.sh ia32". Then I compile the file "ifort xxx.f90" . Finally, the executable file is still 64 bit. Can anyone help me with that?
Thank you
Does your Linux version have 32-bit gcc support installed? What you show should work. Are you on a 64-bit system? (I assume you are on Linux and no OS X.)
Please show the output of:
ifort -dryrun xxx.f90
Emily_Y_
I am working on a 64-bit system and I am working Linux. The following is the output:
/opt/intel/Compiler/11.1/059/bin/intel64/fortcom  \
    -D__INTEL_COMPILER=1110 \
    -D_MT \
    -D__ELF__ \
    -D__INTEL_COMPILER_BUILD_DATE=20091012 \
    -D__unix__ \
    -D__unix \
    -D__linux__ \
    -D__linux \
    -D__gnu_linux__ \
    -Dunix \
    -Dlinux \
    -D__x86_64 \
    -D__x86_64__ \
    -mGLOB_pack_sort_init_list \
    -I. \
    -I/opt/intel/Compiler/11.1/059/include/intel64 \
    -I/opt/intel/Compiler/11.1/059/mkl/include \
    -I/opt/intel/Compiler/11.1/059/include \
    -I/usr/local/include \
    -I/usr/include \
    -I/usr/lib/gcc/x86_64-redhat-linux/4.1.2/include \
    -O2 \
    -mP1OPT_version=11.1-intel64 \
    -mGLOB_diag_file=/tmp/ifortVSRMER.diag \
    -mGLOB_source_language=GLOB_SOURCE_LANGUAGE_F90 \
    -mGLOB_tune_for_fort \
    -mGLOB_use_fort_dope_vector \
    -mP2OPT_static_promotion \
    -mP1OPT_print_version=FALSE \
    -mP3OPT_use_mspp_call_convention \
    -mCG_use_gas_got_workaround=F \
    -mP2OPT_align_option_used=TRUE \
    -mGLOB_options_string=-dryrun \
    -mGLOB_cxx_limited_range=FALSE \
    -mGLOB_as_output_backup_file_name=/tmp/ifortNCIHb2as_.s \
    -mIPOPT_activate \
    -mIPOPT_lite \
    -mGLOB_machine_model=GLOB_MACHINE_MODEL_EFI2 \
    -mGLOB_extended_instructions=0x8 \
    -mP2OPT_subs_out_of_bound=FALSE \
    -mGLOB_ansi_alias \
    -mIPOPT_args_in_regs=0 \
    -mPGOPTI_value_profile_use=T \
    -mP2OPT_hlo_level=2 \
    -mP2OPT_hlo \
    -mIPOPT_obj_output_file_name=/tmp/ifortVSRMER.o \
    "-mGLOB_linker_version=2.17.50.0.6-20.el5_8.3 20061020" \
    -mP3OPT_asm_target=P3OPT_ASM_TARGET_GAS \
    -mGLOB_obj_output_file=/tmp/ifortVSRMER.o \
    -mGLOB_source_dialect=GLOB_SOURCE_DIALECT_FORTRAN \
    -mP1OPT_source_file_name=test00.f90 \
    test00.f90
ld  \
    /usr/lib/gcc/x86_64-redhat-linux/4.1.2/../../../../lib64/crt1.o \
    /usr/lib/gcc/x86_64-redhat-linux/4.1.2/../../../../lib64/crti.o \
    /usr/lib/gcc/x86_64-redhat-linux/4.1.2/crtbegin.o \
    --eh-frame-hdr \
    -dynamic-linker \
    /lib64/ld-linux-x86-64.so.2 \
    -o \
    a.out \
    /opt/intel/Compiler/11.1/059/lib/intel64/for_main.o \
    -L/opt/intel/Compiler/11.1/059/mkl/lib/32 \
    -L/opt/intel/Compiler/11.1/059/tbb/ia32/cc4.1.0_libc2.4_kernel2.6.16.21/lib \
    -L/opt/intel/Compiler/11.1/059/lib/intel64 \
    -L/opt/intel/Compiler/11.1/059/ipp/em64t/lib \
    -L/opt/intel/Compiler/11.1/059/mkl/lib/em64t \
    -L/opt/intel/Compiler/11.1/059/tbb/intel64/cc4.1.0_libc2.4_kernel2.6.16.21/lib \
    -L/usr/lib/gcc/x86_64-redhat-linux/4.1.2 \
    -L/usr/lib/gcc/x86_64-redhat-linux/4.1.2/../../../../lib64 \
    -L/usr/lib/gcc/x86_64-redhat-linux/4.1.2/../../.. \
    -L/lib64 \
    -L/lib \
    -L/usr/lib64 \
    -L/usr/lib \
    -Bstatic \
    -lifport \
    -lifcore \
    -limf \
    -lsvml \
    -Bdynamic \
    -lm \
    -Bstatic \
    -lipgo \
    -lirc \
    -u \
    __pthread_once \
    -Bdynamic \
    -lpthread \
    -lc \
    -lgcc_s \
    -lgcc \
    -Bstatic \
    -lirc_s \
    -Bdynamic \
    -ldl \
    -lc \
    /usr/lib/gcc/x86_64-redhat-linux/4.1.2/crtend.o \
    /usr/lib/gcc/x86_64-redhat-linux/4.1.2/../../../../lib64/crtn.o
rm /tmp/ifort9uqp8Glibgcc
rm /tmp/iforteEXroMgnudirs
rm /tmp/ifortUjU8UWgas
rm /tmp/ifortNCIHb2as_.s
rm /tmp/ifortAhohs7ldashv
rm /tmp/ifortH0Y6Icarg
rm /tmp/ifortsRmYZhgnudirs
rm /tmp/ifortVSRMER.o
How can I check if gcc 32-bit is installed?
Thank you.
Emily
It's pretty clear then that you're using the 64-bit compiler, based on the paths. Please show the source command and after that the value of the path environment variable (echo $path).
Emily_Y_
I use the source command and (echo $path), but there is nothing return.
mecej4
In certain command shells, you may need the command to be echo $PATH instead of echo $path.
Emily_Y_
Thank you so much. I use echo $PATH and the output is here
/usr/lib/openmpi/1.3.2-gcc/bin:/usr/kerberos/bin:/opt/intel/Compiler/11.1/059/bin/intel64:/opt/intel/Compiler/11.1/059/bin/intel64:/usr/local/bin:/bin:/usr/bin:/home/students/yyry2/bin
mecej4
Do you have the 32-bit Intel Fortran compiler package installed? If you did, and you used "ia32" as the argument to the "source ifortvars.sh" command, you should have seen "ia32" in place of "intel64" in $PATH, and the directory /opt/intel/Compiler/11.1/059/bin/ia32 should exist on your system. Please check if this is true.
Emily_Y_
Thank you so much. I use the "source" command, and there is still "intel64" in $PATH. The 32-bit Compiler does not exist. I think this is the reason.
mecej4
In that case, you can try the -m32 flag with the 64-bit compiler. If that works and produces a 32-bit a.out file, you may not need to install the 32-bit ia32-target compiler package.
Emily_Y_
I add the flag like this "ifort -m32 xxx.f90 -o a.out" and it produces this error
catastrophic error: Compiler configuration problem encountered.  The expected target architecture compiler is missing (11.1-ia32 != 11.1-intel64)
compilation aborted for test00.f90 (code 1)
You need to install the 32-bit compiler. Please go to https://registrationcenter.intel.com/ and get it. You may need to install 32-bit gcc libraries since many 64-bit distros omit them.
I'd also recommend installing the latest compiler your license is eligible for.
Emily_Y_
Thank you to Steve. I am going to install that.
