Is there a way to have visual studio (2012) break on intel fortran run time warnings like:
forrtl: warning (402): fort: (1): In call to I/O Write routine, an array temporary was created for argument #2
In the current version, no. In version 15, coming out later this year, yes, by using the new library routine ESTABLISHQQ to establish a run-time handler for Fortran errors. You could then do something like this:
use ifestablish
integer array(50)
procedure(establishqq_handler) :: handler
integer (int_ptr_kind()) :: context
logical :: ret
ret = establishqq(handler, context)
array = 1
call sub (array(1:49:2))
print *, array
end
subroutine sub (a)
integer a(*)
do i=1,25
a(i) = 2 * i
end do
end subroutine sub
function handler (error_code, continuable, message_string, context)
use kernel32
use foriosdef
implicit none
logical :: handler
! Arguments
integer, intent(in) :: error_code ! RTL error code from IOSTAT table
logical, intent(in) :: continuable ! True if condition is continuable
character(*), intent(in) :: message_string ! Formatted message string a la ERRMSG/IOMSG
integer, intent(in) :: context ! Address-sized integer as passed in to call to ESTABLISHQQ ! For whatever purpose the programmer desires.
handler = .TRUE. ! Continue by default
if (error_code == FOR$IOS_WARN_TBACK) then ! Runtime warning with traceback
print *, message_string
if (IsDebuggerPresent() /= 0) call DebugBreak ! Break into debugger
end if
end function handler
