29274 Discussions
problem with installation m_fc on Mac OS Core 2 MBP
Falk_Herwig
Hi I am trying to evaluate the intel 9.1 fortran compiler for Mac OS X. I have downloaded the *.dmg file and started the installer program. I get to the screen "Easy Install on Macintosh HD - Click Install to perform a basic installation ... " When I click "install" the installer quicly moves through the install window and comes back at the Finish up screen with the message "There were errors installing the software - Please try installing again". I did but the same result.
After this the /opt dir is still empty. Yes, I have enough disk space. I tried to use the license number and the license file. I also can not install the debugger.
I talked to a friend who appeared to have a similar problem with the m_fc_c_9.1.020.dmg but not with the m_fc_c_9.1.030.dmg.
I tried both the m_fc_c_9.1.030.dmg and m_fc_c_9.1.032.dmg.
My system is a brand new MacBook Pro with Intel Core 2 Duo, Mac OS 10.4.8.
Any help appreciated, Falk Herwig.
Steven_L_Intel1
Please report this to Intel Premier Suppport - you'll get the help you need.
