problem with mcmodel=large -shared-intel linking with libifcoremt.a "relocation truncated to fit: R_X86_64_PC32 message_catalog
rdees
I'm having a similar problem that "alaryme" had on 12/17/2009   I have a very large (i.e. > 2 Gb) comined Fortran/C code that also must link with several MKL libraries and openmp libraries.  Everything works great as long as I stay less than 2 Gb.  To make my code larger I added the mcmodel=large and -shared-intel to both the compile argument lists and the link argument list.  It all seems to work okay for my fortran compiles, and my C compiles, but it doesn't appear to be linking correctly to the INTEL library libifcoremt.a    Can anyone help me?  LIsted below is the output:
ifort saramain3.o adjust.o ave_subs.o assemble.o vsurfcp.o xpression.o arpack.o eigena.o /common/progs/lapackblas/lib/intel64/libmkl_lapack.a /opt/intel/composerxe-2011/mkl/lib/intel64/libmkl_solver_lp64.a -Wl,--start-group /opt/intel/composerxe-2011/mkl/lib/intel64/libmkl_intel_lp64.a /opt/intel/composerxe-2011/mkl/lib/intel64/libmkl_intel_thread.a /opt/intel/composerxe-2011/mkl/lib/intel64/libmkl_core.a -mcmodel=large -shared-intel -static-intel -Wl,--end-group -openmp -lpthread -o ./sara3d_pard_drs
/opt/intel/fce/10.1.011/lib/libifcoremt.a(for_diags_intel.o)(.text+0x17): In function `for__message_catalog_close':
: relocation truncated to fit: R_X86_64_PC32 message_catalog
/opt/intel/fce/10.1.011/lib/libifcoremt.a(for_diags_intel.o)(.text+0x941): In function `for__io_return':
/opt/intel/fce/10.1.011/lib/libifcoremt.a(for_diags_intel.o)(.text+0xac9): In function `for__io_return':
/opt/intel/fce/10.1.011/lib/libifcoremt.a(for_diags_intel.o)(.text+0xad2): In function `for__io_return':
/opt/intel/fce/10.1.011/lib/libifcoremt.a(for_diags_intel.o)(.text+0xb23): In function `for__io_return':
/opt/intel/fce/10.1.011/lib/libifcoremt.a(for_diags_intel.o)(.text+0xc4e): In function `for__issue_diagnostic':
/opt/intel/fce/10.1.011/lib/libifcoremt.a(for_diags_intel.o)(.text+0xe69): In function `for__issue_diagnostic':
: relocation truncated to fit: R_X86_64_PC32 for__l_excpt_info
/opt/intel/fce/10.1.011/lib/libifcoremt.a(for_diags_intel.o)(.text+0xf58): In function `for__issue_diagnostic':
/opt/intel/fce/10.1.011/lib/libifcoremt.a(for_diags_intel.o)(.text+0xf61): In function `for__issue_diagnostic':
/opt/intel/fce/10.1.011/lib/libifcoremt.a(for_diags_intel.o)(.text+0xf9e): In function `for__issue_diagnostic':
/opt/intel/fce/10.1.011/lib/libifcoremt.a(for_diags_intel.o)(.text+0xfaf): In function `for__issue_diagnostic':
: additional relocation overflows omitted from the output
make: *** [sara3d] Error 1
Steven_L_Intel1
Take out -static-intel
rdees
Steve - Thank you very much.  Taking out the -static-intel fixed everything.
Steven_L_Intel1
Glad to hear it. -static-intel was overriding -shared-intel, which is required to make this work.
Ben_Foster
I am compiling w/ intel 12.1.5
mpif90 -r8 -heap-arrays -mcmodel=large -shared-intel
and am getting the relocation errors, e.g.:
for_diags_intel.c:(.text+0xa6c): relocation truncated to fit: R_X86_64_PC32 against symbol `message_catalog' defined in COMMON section in /ncar/opt/intel/12.1.0.233/composer_xe_2011_sp1.11.339/compiler/lib/intel64/libifcore.a(for_diags_intel.o)
for_diags_intel.c:(.text+0xbdb): relocation truncated to fit: R_X86_64_PC32 against symbol `message_catalog' defined in COMMON section in /ncar/opt/intel/12.1.0.233/composer_xe_2011_sp1.11.339/compiler/lib/intel64/libifcore.a(for_diags_intel.o)
for_diags_intel.c:(.text+0xbeb): relocation truncated to fit: R_X86_64_PC32 against symbol `message_catalog' defined in COMMON section in /ncar/opt/intel/12.1.0.233/composer_xe_2011_sp1.11.339/compiler/lib/intel64/libifcore.a(for_diags_intel.o)
for_diags_intel.c:(.text+0xc46): relocation truncated to fit: R_X86_64_PC32 against symbol `message_catalog' defined in COMMON section in /ncar/opt/intel/12.1.0.233/composer_xe_2011_sp1.11.339/compiler/lib/intel64/libifcore.a(for_diags_intel.o)
/ncar/opt/intel/12.1.0.233/composer_xe_2011_sp1.11.339/compiler/lib/intel64/libifcore.a(for_diags_intel.o): In function `for__issue_diagnostic':
I have reduced my static memory allocations in several places. I am using the
Linux "size" command to locate where I am allocating large static arrays, e.g.,
"size *.o >! size.out". How do I determine my total static memory usage, so I
know how much I have to reduce to get under the 2GB limit? Do I total all numbers
under the bss column?
I am also linking netcdf v4.2. Thanks for any help,
--Ben
foster@ucar.edu
jimdempseyatthecove
The size of the .o file is not necessarily related to the size of the memory consumed by the .o file after linking. Try using objdump on the object files being linked. This may expose a large static object. See: http://linux.die.net/man/1/objdump
You may also want to try readelf http://www.ibm.com/developerworks/aix/library/au-unixtools.html
Jim Dempsey
