29391 Discussions
problem with use of DFPORT library
phil5000
i have the following code to re-seed a random number stream:
subroutine SetSeed (seed)
!i have the relevant meta commands in here
use DFPORT
real(4) seed
call SRAND(seed)
end
I have compiled this and created a debug version of the DLL, which i call from VB. When i execute the line
call SRAND(seed)
a dialogue box appears asking me to specify a path for the library file DFPORT.FOR. The library file I have installed on my machine is DFPORT.F90, as I would have expected, and so I can not get this line to execute and re-seed the random number.
I have the same problem with the function to generate the random number which uses DRAND().
What am I doing wrong ?
Phil.
phil5000
an afterthought - dont know if it is relevant, but i am using windows 2k, and compaq vf professional 6.1.0.
phil
Steven_L_Intel1
Use Step Over, not Step Into. You're stepping into the source of SRAND, which isn't available to you.
Steve
phil5000
thanks - the seeder seems to work ok. now having problems with the generator - I want double precision random numbers, so i am using DRAND in the following DLL function:
function GetRand()
use DFPORT
!DEC$ attributes dllexport :: GetRand
!DEC$ attributes alias : "GetRand" :: GetRand
real(8) GetRand
GetRand = DRAND(0)
return
end
When i call the dll function from XL I get an access violation error ????
grateful for any help.
phil.
durisinm
Have you declared the value returned by GetRand as double precision in Excel?
Mike
phil5000
thanks - but i had the following VBA declare statement, which does as you suggest, i think...
Declare Function GetRand _
Lib "h:...simstuff.DLL" () As Double
I have another couple of things to check but it looks OK to me ??
obviously any other ideas would be gratefully received - getting this working is rather a fundamental element of what I am trying to do.
phil.
phil5000
the one other aspect of this i am not sure about is how the random no generator uses the seed to control the stream of random numbers. Am i doing this correctly ?
First I call the seeding subroutine:
use DFPORT
real(4) seed
call SRAND(seed)
end
from the VB sub:
Sub vbSetSeed()
Dim X As Single
X = Range("Seed").Value
Call SetSeed(X)
End Sub
(which seems to be working)
Then I execute a function call from VB to ask for the random number from the seeded stream:
VBGetRand = GetRand()
where GetRand is as described in the previous post.
Is this use of SRAND(seed) and DRAND(0) consistent ?
thanks again
Phil.
Steven_L_Intel1
Have you considered using the standard Fortran intrinsic RANDOM_NUMBER (and RANDOM_SEED) instead? It's a better generator and is probably easier to understand.
Steve
phil5000
i might have to try it - can i use RANDOM_NUMBER to generate real(8) rather than real(4) numbers ? Also, because I have to generate a very large number of random nos, i have done a bit of work testing the true randomness of the rand() stream and it seems to be quite good. I do not know if random_number is as good - i am pretty wary of most pseudo rn generators.
Also I'd still like to understand why my use of SRAND and DRAND is not working.
Phil
Steven_L_Intel1
Yes, RANDOM_NUMBER can return REAL(8). It's a very good generator - L'Ecuyer '83.
Steve
