problems with cshift
jft27
I'm having a problem using chsift that doesn't make a lot of sense to me.
the following code works,
a(:, i:j) = chsift(a(:, i:j), shift = (/x, x, x/), dim =1)
but if i replace the shift with an array with value x and size 3 it goes out of bounds according to the results of compiling with -CB
what stupid thing am I doing wrong?
thanks
Jeremy
I can't reproduce the problem based on this one line. Please submit a support request to Intel Premier Support and attach a small but complete program that demonstrates the problem. Or you can post a small but complete problem here for people to look at.
jft27
okay here's an example where it does work
program shiftprob
  !the idea of the program is that if we store a block diagonal matrix
  !in a way where none of the zeros are kept and we then want to recover the
  !full structure then the function undiag will stick the blocks onto the diagonal parts of the array.
  implicit none
  integer, parameter :: npol=3
  real :: a(npol, 4*npol), b(4*npol, 4*npol)
  a = 1.0 !a is where the matrix is stored
  b = undiag(a) !b will be block diagonal with the elements of a on the 'diagonal'
  print*, 'a', a
  print*, 'b', b
contains
  function undiag(x)
    real, dimension(:, :) :: x
    integer :: n, i, shift(npol)
    real, dimension(size(a, 2), size(a,2)) :: undiag
    n = size(x, 2)
    undiag = 0.0
    undiag(1:npol, :) = x
    do i = 1, n - npol + 1, npol
       shift = i-1
       undiag(:,i:i+npol-1) = cshift(undiag(:, i:i+npol-1),shift = (/i-1, i-1, i-1/) , dim = 1)
    end do
  end function undiag
end program shiftprob
and here's one where it doesn't
program shiftprob
  implicit none
  print*, 'a', a
  print*, 'b', b
contains
  function undiag(x)
    n = size(x, 2)
    undiag = 0.0
       shift = i-1
       undiag(:,i:i+npol-1) = cshift(undiag(:, i:i+npol-1),shift = shift , dim = 1)
    end do
  end function undiag
compile with
ifort -CB shiftprob.f90 -o shiftprob
hope someone can tell me what I'm doing wrong
thanks
Jeremy
Message Edited by Steve_Lionel on 12-13-2005 12:58 PM
Hmm - works for me. What do you get when you type:
ifort -what shiftprob.f90
jft27
Intel Fortran 9.0-5238
thanks for helping
Jeremy
Hmm, that's somewhat old. There's an update coming out later this week - try it on that and let me know what happens.
