problems with errset
kageist
I am trying to make a VAX fortran code work on intel fortran for windows. The problem is it has a "call errset" statement. My understanding is "errset" isn't used in intel fortran. I'm having trouble figuring out how to produce a similar result in intel fortran without using errset. Any suggestions on this or where to look? Thank you in advance.
Tell us what you were using ERRSET for. It has many possible uses. Some of them might be doable in Intel Fortran. If you don't know what the call does, then show us the call and I'll figure it out.
kageist
Here's the section with errset. The three lines are indented so they will stand out. My job won't allow me to send you the whole file. Mylimited understanding is that it's supposed tostore errors for later viewing. I hope this is enough. Thank you in advance.
PRINT*,'ENTER INPUT FILE NAME'
READ(*,'(A)')FINP
FTMP='TEMP.DAT'
DO J=80,1,-1
IF (FINP(J:J).EQ.'.') GO TO 91
END DO
91 FLST=FINP(1:J)//'LST'
FSUM=FINP(1:J)//'SUM'
FACC=FINP(1:J)//'ACC'
OPEN (JLST,NAME=FLST,TYPE='NEW')
OPEN (JSUM,NAME=FSUM,TYPE='NEW',
* CARRIAGECONTROL='LIST')
OPEN (JACC,NAME=FACC,TYPE='NEW',
!CLEAN INPUT FILE FROM LINES THAT STARTS WITH "*"
CALL CLEAN_FILE(FINP,FTMP)
! READ FROM THE CLEANED INPUT FILE
1 CALL ERRSET(72,.TRUE.,.FALSE.,.FALSE.,.FALSE.,32767)
CALL ERRSET(73,.TRUE.,.FALSE.,.FALSE.,.FALSE.,32767)
CALL ERRSET(88,.TRUE.,.FALSE.,.FALSE.,.FALSE.,32767)
NRUN=NRUN+1
CALL GUSTA (FTMP,FLST,FSUM,FACC)
CALL GUSTD
CALL GUSTE
CALL GUSTF
CALL GUSTG
CALL GUSTL
CALL GUSTS
CALL GUSTT (NRUN)
GO TO 1
END
Ok. What these do is tell the program to continue execution when a floating overflow or divide by zero is seen. (88 is for an overflow in the math library.) It does not "store them for later". The operation that would get the error instead stores a VAX reserved operand in the result.
I would suggest simply commenting out those calls. By default, Intel Fortran uses IEEE floating point semantics which continue on these errors and give you an Infinity or a NaN (Not a Number). If these are used in a later calculation, then you may get other results. Try it and see. There are other, newer ways of controlling floating point behavior but I don't want to get into that yet. I think that just removing the calls will give you behavior closer to what the VAX would do.
kageist
Thank you! Commenting them out doesn't cause any problems so that's what I did.
Glad to hear it.
