29657 Discussions
program doesn't call to system command
jpprieto
Hi, I'm working with a f90 program compiled with ifort. In a routine the program call to system command to create a directory
if(ndim>1)then
filedir='output_'//TRIM(nchar)//'/'
filecmd='mkdir -p '//TRIM(filedir)
#ifdef NOSYSTEM
if(myid==1)call PXFMKDIR(TRIM(filedir),LEN(TRIM(filedir)),O'755',info)
#else
!HERE
if(myid==1)call system(filecmd)
#endif
#ifndef WITHOUTMPI
call MPI_BARRIER(MPI_COMM_WORLD,info)
#endif
The program compiles in a good way and run normally, but when it tries to open the created directory stop with
forrtl: No such file or directory
forrtl: severe (29): file not found, unit 11, file /usr/local/sge/users/test/jpprieto/ramses/output_00001/info_00001.txt
I'm sure that all conditions to call system are satisfied, but the program doesn't creat the directory. The program skip the line with "call system(filecmd)".
Some body can help me?
Ron_Green
JP,
use this option -save-temps
this will keep a copy of the FPP preprocessed file in your local directory. It will be named .i90 (if the source is .F90) or .i (if the source is .F )
See if your defines are correct.
But I see something else that may be a problem. if you:
USE IFPORT
then SYSTEM is a function and not a subroutine. You should have something like:
I = SYSTEM(filecmd)
jpprieto
JP,
USE IFPORT
I = SYSTEM(filecmd)
Hi. Well. Let me you know something more. This program is a modified version of other program that work in a good way. The .f90 in which system command is called wasn't modified by me, I mean, these lines are identical to the previous version, in which the system command is called and creates the directory.
About write I = SYSTEM(filecmd), this doesn't work.
I hope you can help me.
Thank you.
Ron_Green
Super, I am glad it was working in a past context.
Now, let's try some coding:
Change:
to
if (myid==1) then
print "creating directory from parent dir"
i = system( 'pwd' )
print "mkdir command is", filecmd
i = system( filecmd )
print "stopping"
stop
end if
this might help you determine what is happening. the 'pwd' command will show where the code has it's current working directory, as your mkdir command is not using absolute paths but relative paths. Add to this knowledge the actual command you are issuing with filecmd.
ron
jpprieto
Change:
to
if (myid==1) then
i = system( 'pwd' )
print "stopping"
stop
end if
ron
Hi, ron.
what is the variable type of "i"? I defined it as character(LEN=80), but the program didn't compile.
So I did the following modifications:
if(myid==1) then
write(*,*)'creating directory from parent dir'
call system( 'pwd' )
write(*,*)'mkdir command is', filecmd
call system( filecmd )
write(*,*)'stopping'
stop
end if
And I got the following output:
mkdir command is
mkdir -p output_00001/
stopping
So, the program doesn't execute the comand "pwd" and the directory output_00001/ hadn't created.
Well, really I don't know what's up.
Thank you.
Ron_Green
According to the system documentation, i should be INTEGER.
so change back to
integer :: i !..must go at top of procedure with other data declarations
i = system( 'pwd' )
and
You cannot 'call' system, this is incorrect and is not working.
ron
