sanity check
anamika_shrivastava_
config.log1
Respected sir,
I am anamika shrivastava. and i want to install the netcdf-3.6.2using the intel compiler. but i am getting error of icc fails sanity check.I am not getting which type of error is this, and how can i solve this. for this reason i attaching my bashrc file and config.log file and system detail.please tell me how can come out from thris problem.my bashrc file is::;;;;;;;;;;
# .bashrc
#User specific aliases and functions
# Source global definitions
if [ -f /etc/bashrc ]; then
. /etc/bashrc
alias c=clear
alias ls='ls -F'
alias rm='rm -i'
fi
export HOME_PATH=home/bin:home/etc:$HOME_PATH
export WRFPATH=home/asf15076/WRF/WRFV3/:home/asf15076/WRF/WRFV3/external/:home/asf15076/WRF/WRFV3/frame:home/asf15076/WRF/WRFV3/phys:$WRFPATH
export WPS=home/asf15076/WRF/WPS/:$WPS
#export NETCDF=/home/asf15076/netcdf-3.6.2
#export NETCDF_BIN=home/asf15076/netcdf-3.6.2:$NETCDF_BIN
#export NETCDF_LIBDIR=/home/asf15076/netcdf1/lib:$NETCDF_LIBDIR
#export NETCDF_INCDIR=/home/asf15076/netcdf1/include:$NETCDF_INCDIR
############# set up a editor for program
set EDITOR='vi'
set history =40
set MP_STACK_SIZE =64000000
PATH=/bin:/usr/bin:/usr/sbin:/share/apps/intel/fce/9.0/bin:/share/apps/intel/cce/9.0/bin:/share/apps/intel/idbe/9.0/bin:/opt/intel/mpi/2.0.1/bin64:/share/apps/intel/fce/9.0/include:/share/apps/intel/cce/9.0/include:$PATH
export PATH
export LM_LICENSE_FILE=/share/apps/intel/fce/9.0/licenses:/share/apps/intel/cce/9.0/licenses:/opt/intel/licenses:$LM_LICENSE_FILE
export LD_LIBRARY_PATH=/usr/lib:/share/apps/intel/fce/9.0/lib:/share/apps/intel/cce/9.0/lib:/share/apps/intel/idbe/9.0/lib:/opt/intel/mpi/2.0.1/lib64:$LD_LIBRARY_PATH
export LIBPATH=/usr/lib:/share/apps/intel/fce/9.0/lib:/share/apps/intel/cce/9.0/lib:$LIBPATH
FPATH=/share/apps/intel/fce/9.0/include:/share/apps/intel/cce/9.0/include:$FPATH
export FPATH
INCLUDE=/opt/intel/mpi/2.0.1/include64:$INCLUDE
export INCLUDE
MANPATH=/share/apps/intel/fce/9.0/man:/share/apps/intel/cce/9.0/man:$MANPATH
export MANPATH
########## some useful aliases ##############
alias rm='rm -i'
alias cp='cp -i'
alias mv='mv -i'
alias ls='ls -F'
export CC="/share/apps/intel/cce/9.0/bin/icc"
export F90="/share/apps/intel/fce/9.0/bin/ifort"
export F77="/share/apps/intel/fce/9.0/bin/ifort"
export FC="/share/apps/intel/fce/9.0/bin/ifort"
export CPP=icc
export CXX=/share/apps/intel/cce/9.0/bin/icpc
export LC=ifort
export LDFLAGS="-L$LD_LIBRARY_PATH"
export SHLIB_CXXLD="icpc"
export PROCESSFLAGS=-DpgiFortan
export CFLAGS="-O0 -mp1 -i-static -no-gcc -w"
export CPPFLAGS="-fPIC -DpgiFortran"
export FFLAGS="-O2 -mp -i-static -w"
export F90FLAGS="-O2 -mp -i-static -w"
export CXXFLAGS="-O2 -mp -i-static -w"
export MPIRUN="/opt/intel/mpi/2.0.1/bin64/mpirun"
export MPI_F90="/opt/intel/mpi/2.0.1/bin64/mpiifort"
set LC_ALL="C"
TimP
I can't decipher from your attachments the actual contents of the conftest.c which failed.
I'd point out that icc 9.0 wasn't in use for long, as 9.1 was much improved. I don't know which versions of gcc were supported by icc 9.0, but certainly a recent version of gcc could provoke your pre-processing failure with the old icc.
It does appear, from the fact that the version of netcdf you chose is supported under FC9, that your build may expect versions of gcc and glibc which are too new to work with the old Intel tools releases.
Did you check:
your kernel and linux version is new enough for your version of netcdf, yet old enough for the obsolete Intel software tools?
similar with glibc and gcc?
Your icc documentation would tell at least which linux distros were in use when it was tested.
Stephen_D_Intel
Hi Anamika,
You should review this Knowledge Base article on building NetCDF:
http://software.intel.com/en-us/articles/performance-tools-for-software-developers-building-netcdf-with-the-intel-compilers/
I noticed that you are not using this definition of CPP for the C preprocessor command:
export CPP='icc -E'
this sort of thing is covered in the KB article.
