29376 Discussions
substring ending point 13 greater than variable length 13
jberkery
I'm using MS VC 9 and Intel Fortran 10.1 on Windows64. I'm passing some strings from C to Fortran.
---- C call
SETPR(cstr1, len1, cstr2, len2, cstr3, len3);
---- Fortan
Subroutine setpr( cstr1, cstr2, cstr2)
Use fmod, only: fstr1, fstr2, fstr3
character*(*) cstr1, cstr2, cstr3
fstr1(1:6)=cstr1(1:6)
fstr1(1:4)=cstr1(1:4)
fstr1(1:13)=cstr1(1:13)
In the debugger I see all the C strings and their lengths correctly and the matching F strings from a module are of the same size.
cstr1 character(6)
cstr2 character(4)
cstr3 character(13)
fstr1 character(6)
fstr2 character(4)
fstr3 character(13)
It does the assignment just fine for strings 1 and 2 but then I get this error on the third.
fortrtl: severe (408): fort: (4): Variable cstr3 has substring ending point 13 which is greater than the variable length of 13
jberkery
I'm passing the length as size_t which should be 32 in win32 and 64 on win64, no?
Yes. However, I also see that you are passing the lengths immediately after the addresses. This was the default for CVF but isn't for Intel Fortran unless you have /iface:CVF specified (or /iface:mixed_str_len_arg). The IVF default is to put the lengths at the end.
jberkery
Yes, because we still compile this lib with CVF 6.6 as well, I do have iface:cvf.
The input argument is recognized as character(13) so it must be seeing the length 13.
There's a 4th string that I haven't shown. It's of length 70 and the debugger shows me character(70) with the correct string contents, so the info is being received. I just can't assign it to the string from the ftn module.
Can you construct a short but complete test case that demonstrates the problem and attach it here?
jberkery
Well, I tried and it was fruitless. It works like a charm when isolated. Since my Ftn strings originate in a module full of named commons, legacy code that has a 35 year history, I'm going to have to assume something else stepped on that string space. I have to roll my sleeves up and dumpster dive then. This did used to work under 64 bit Unix though. Sorry to use your time.
The first thing I would do with the original code is step through the instructions that build up the argument list in the C code that calls Fortran and make sure that each of the arguments is what I expect it to be. On x64 it's a bit more complicated because the first six (I think?) arguments are in registers.
Next I might step through the code that does the string bounds check on the Fortran side and see where the data is coming from. The particular symptom you show, where the length and bound seem to be ok, can be a sign that the high 32 bits of one of the lengths is improperly set.
