Does global override local when we set project for Fortran?
Here, I mean by global and local:
global: setting on the property window after right click on the Fortran project.
local: setting on the property window after right click ona specific Fortran file.
It seems to me global overrides the local.
-BO
"Global" I think of as the project defaults. This is the base set of options to be applied to the whole project.
"Local" I think of as source-file specific options. These should take precedence over project defaults.
Often one wants to build an entire project with one set of options BUT perhaps a handful of source files need either more optimization or less optimization. Thus, the "local" or file-specific options should take precedence.
Consult your build log for the definite answer.
ron
ron
Ron is correct - properties that you set for individual files override the project-wide setting.
