protected procedure pointer
MR
When compiling the attached code with ifort I get:
error #8171: This is not a valid attribute for the procedure declaration statement. [PROTECTED]
procedure(i_f), pointer, protected :: p_f => null()
compilation aborted for protected-procpointers.f90 (code 1)
However, from the standard I see
C535 (R501) The PROTECTED attribute is permitted only for a
procedure pointer or named variable that is not in a common block.
so I think that the code is fine.
ifort -V
Intel Fortran Intel 64 Compiler Professional for applications running on Intel 64, Version 11.1 Build 20100414 Package ID: l_cprof_p_11.1.072
Copyright (C) 1985-2010 Intel Corporation. All rights reserved.
module m
implicit none
abstract interface
pure function i_f(x) result(y)
real, intent(in) :: x
real :: y
end function i_f
end interface
!procedure(i_f), pointer :: p_f => null() ! this works
end module m
I agree that your code is legal and that the compiler should accept this. I'll report it to the developers. The issue ID is DPD200156432.
MR
OK, thank you!
Marco
Marco,
The standards committee realized that the standard did not have appropriate wording regarding the PROCEDURE statement to allow this usage, but it was intended that it should work. An interpretation has been filed and we'll fix the compiler.
I expect this to be fixed in the next major release, scheduled for November.
