quickwin dialogs
Intel_C_Intel
hello,
how can i activate input values entered by a user in a dialog box? and how can i display a calculated value in an edit box or a location in the window? need these for now...
isn-removed200637
It is all in the documentation. Use DLGGETINT, DLGGETCHAR to get the
INTEGERs or CHARACTER strings that are entered,
do Internal reads to convert numbers as character strings
to Integers or floating-point numbers in order to do
some computations with them, then do internal WRITES to
convert integers, reals etc. to character-strings that
you can then output to dialogs using DLGSET. For example
INTEGER*4 SLIDE1, SLIDE2, SLIDE3
REAL*8 A1,A2,A3
CHARACTER*256 ANG1,ANG2,ANG3,A1CHAR,A2CHAR,A3CHAR
INTEGER*4 INTA1,INTA2,INTA3
 CASE(IDC_ANGLE2_SLIDER)
	retlog=DLGGETINT(dlg, IDC_ANGLE2_SLIDER, SLIDE2, DLG_POSITION)
!	WRITE(*,*) 'ANGLE 2 SLIDER = ',SLIDE2
	INTA2=2*(SLIDE2-1)
	A2=INTA2
	WRITE(ANG2,*)INTA2
	retlog=DLGSET(dlg, IDC_ANGLE2,TRIM(ADJUSTL(ANG2)), DLG_STATE)
	retlog=DLGSET(dlg, IDC_ANGLE2,.TRUE., DLG_ENABLE)
 CASE(IDC_ANGLE2)
 !WRITE(*,*) 'ANGLE 2 SET '
	!GET THE ANGLE
	retlog=DLGGET(dlg, IDC_ANGLE2,ANG2,DLG_STATE)
	A2LENG=LEN_TRIM(ANG2)
	A2=0
	IF(A2LENG.GT.0)	READ(ANG2,*) A2
	SLIDE2=(INT(A2+0.1)/2)+1
	retlog=DLGSET(dlg, IDC_ANGLE2_SLIDER, SLIDE2, DLG_POSITION)
HTH
