Static library in studio.NET
melander
How does one add a static library in studio.NET?
I tried this, but LNK did not find the library
(1)Under the Tools/options/Intel Fortran Options tab I added
the full path to the library.
(2) I added the .lib file under project/add existing item
Both code and library work fine under the old Microsoft Fortran Power Station. Both code and library complies OK
with Intel fortran. The library also builds OK, but when I go to build the .exe the linker can't find the library.
There obviously should be a simple solution, but I don't see it. Thanks in advance for any help.
-M.
(1) is not the right place - this is a list of folders that it will search for libraries, but there has to be a reference to the library somewhere
(2) should have worked. Another place you can do this is the Properties page for the project. Right click on the project name, select Properties, Linker, Input. Give the path to your library in the "Additional Dependencies" field.
Steve
melander
Thanks for the help.
I found a solutions that works.
(1) I add the path or folder name under Tools/... libraries, and (2) I add the Library name under Project/Properties/... Addtional dependencies.
-M.
I did some experiments, and indeed you're correct - adding a .lib or even a .obj to the project accomplishes nothing. I'll ask as to why this is... The solution you came up with works fine.
Steve
