29277 Discussions
"0xC0000005: Access violation executing location" when calling interface subroutine
lxander
I have a fairly simple console program that takes a single argument from the command line and the implements a progress update (to eventually be used in a larger program) ...
  ! fortranconsole.f90
  program Console
  use MyLib
  implicit none
  !character(:), allocatable ::                             taskId
  character(len=36) :: taskId
  procedure(ProgressUpdateAction), pointer :: progressUpdate
  ! Print splash line
  print *, 'Analysis Console'
  call ProcessCommandLine(taskId)
  ! Print the task id to the command line
  print *, taskId
  call DoWork(progressUpdate)
  contains
  subroutine ProcessCommandLine(taskId)
  character(len=36), intent(out) :: taskId
  integer :: myArgLength
  integer ::myStat
  ! Check command line for supplied arguments
  if (Command_argument_count() == 0) then
    stop "Error: There were no command line arguments."
  end if
  call Get_command_argument(1, length=myArgLength, status=myStat)
  if (0 < myStat) then
    stop "Error: Could not retrieve the first command argument."
  end if
  if (36 < myArgLength) then
    stop "Error: Argument more than 36 characters long."
  end if
  ! Get first argument
  call Get_command_argument(1, value=taskId, status=myStat)
  if (myStat /= 0) then
    stop "Error GET_COMMAND_ARGUMENT failed unexpectedly."
  end if
  end subroutine
  end program
  ! modules.f90
  module MyLib
  implicit none
  interface
  subroutine ProgressUpdateAction(percentProgress)
  integer, intent(in) :: percentProgress
  end subroutine
  end interface
  contains
  subroutine DoWork(progressUpdate)
  !DIR$ ATTRIBUTES DLLEXPORT :: DoWork
  !DIR$ ATTRIBUTES ALIAS: 'DoWork' :: DoWork
  !DIR$ ATTRIBUTES REFERENCE :: progressCallBack
  procedure(ProgressUpdateAction), intent(in), pointer :: progressUpdate
  integer, parameter :: STEP_COUNT = 9
  integer, parameter :: OP_COUNT = 100000000
  integer :: i, j, percentProgress
  real(8) :: n
  do i = 1, STEP_COUNT
    ! Update the status.
    percentProgress = (i - 1) * 100.0 / STEP_COUNT
    call progressUpdate(percentProgress)
    ! Do something expensive.
    !do j = 1, OP_COUNT
    !  n = sqrt(real(j,8))
    !  if (j == OP_COUNT) print *, n
    !end do
  end do
  end subroutine
  end module
When I try to debug the code in VS2022 (v16.0.6), I get this ...
... which looks to be where the call to progressUpdate is made.  If I run the executable from the command line I get this ...
My compiler/IDE/etc. setup (which is all the latest installs) ...
Am I doing something wrong in implementing the interface?  Is the procedure/pointer throwing things off?
Many thanks.
IanH
In the blog post that you link to, the author has written the equivalent of a Fortran procedure in C# that does something (it writes to the console) when the DoWork subroutine requests a progress update by invoking the progressUpdate procedure pointer. There's nothing equivalent to that in your code.  How does your code know what to do when a progressUpdate is requested?
You could write a procedure something like:
module MyThings
  implicit none
contains
  ! This procedure matches the characteristics
  ! defined by the ProgressUpdateAction abstract interface
  ! in the MyLib module.
  subroutine my_progress_updater(percentProgress)
    write (*, "('I am about ',i0,'% of the way there.')")  &
        percentProgress
  end subroutine my_progress_updater
end module MyThings
and then pointer assign progressUpdate prior to the call to DoWork
use MyThings
progressUpdate => my_progress_updater
(The author of the blog post made the progressUpdate thing a procedure pointer possibly because of some idiosyncrasy associated with interfacing with C# (or possibly because they just like pointers).  But there's no need for it in a a Fortran-Fortran case.)
Arjen_Markus
At a first glance I would say that you forgot to define the procedure pointer. At least, I do not see a statement like:
progressUpdate => progressUpdateAction
or something similar.
lxander
Thanks @Arjen_Markus .  Tried your suggestion by inserting that statement below line 20 in modules.for (in the MyLib module).
  ! modules.f90
  module MyLib
  implicit none
  interface
  end subroutine
  end interface
  contains
  progressUpdate => progressUpdateAction ! <--
  real(8) :: n
    !do j = 1, OP_COUNT
    !end do
  end do
  end subroutine
  end module
Tried compiling and get "Warning warning #8889: Explicit interface or EXTERNAL declaration is required. [DOWORK]" (referring to line 22 in fortanconsole.for) and then a bunch of errors.
I also tried putting that statement below line 12 in fortranconsole.f90 ...
  program Console
  use MyLib
  implicit none
  ! Print splash line
  print *, taskId
  contains
  integer ::myStat
  end if
  end if
  end if
  end if
  end subroutine
  end program
... but instead get "Error error LNK2019: unresolved external symbol PROGRESSUPDATEACTION referenced in function MAIN__ fortranconsole.obj" and "fatal error LNK1120: 1 unresolved externals x64\Debug\FortranConsole.exe".
I don't think what I'm trying to do is too wild.  The code is based off of Calling Fortran from C# – Monitoring Progress Using Callbacks.  Any other suggestions?  Could there be something in the project properties that I need to set?
Arjen_Markus
Definitely nothing too wild :), but what I meant to explain is that the pointer you pass to the routine DoWork must be pointing to an existing routine. Now you use the name of the interface. Your second solution is the way to go (because otherwise you could leave out the argument altogether), but you need an actual routine to do the work.
IanH
module MyThings
  implicit none
contains
        percentProgress
end module MyThings
use MyThings
lxander
Thank you @Arjen_Markus and @IanH .  Your responses have provided the solution I was looking for.  I really appreciate the speedy replies.
I have updated my code and it compiles and run fine.  Here is where I ended up ...
  program Console
  use Library
  implicit none
  procedure(IProgressUpdateAction), pointer :: progressUpdate
  ! Print splash line
  print *, taskId
  progressUpdate => ProgressUpdateAction
  contains
  integer ::myStat
  end if
  end if
  end if
  end if
  end subroutine
    percentProgress
  end subroutine
  end program
  ! modules.f90
  module Library
  implicit none
  interface
  subroutine IProgressUpdateAction(percentProgress)
  end subroutine
  end interface
  contains
  procedure(IProgressUpdateAction), intent(in), pointer :: progressUpdate
  real(8) :: n
    !do j = 1, OP_COUNT
    !end do
  end do
  end subroutine
  end module
Khalik_K_Intel
This issue has been already resolved by our community members. Therefore, we will no longer respond to this thread.
If you require some further assistance from Intel, please start a new thread.
Any further interaction in this thread will be considered community only.
Khalik.
