"ALLOCATE error" revisited
Mike_M_1
First of all, thanks to the many of you who responded to my earlier post on this subject. So far, the problem seems to have been with use of the FLOOR intrinsic when the real argument wasn't within acceptable bounds for an INTEGER. The run-time monitor apparently did not recognize this problem when it occurred, and the problem was manifested when arrays were (DE)ALLOCATEd, giving an incorrect indication of the cause of the problem. Mahalo, Mike
