29273 Обсуждение
"Error in opening the Library module file."
tobias-burnus
Начинающий
1 026Просмотр.
I get with l_fc_pc_8.1.025 the following error message:
ifort -cm -W0 -O3 -r8 -DCPP_APC -DCPP_DOUBLE -DCPP_INVERSION -c plot_od.F
fortcom: Error: plot_od.F, line 29: Error in opening the Library module file. [fn#fn]
USE m_outcdn
But: m_outcdn.mod exists (produced from outcdn.F = MODULE m_outcdn)
Any ideas?
Tobias
0 баллов
5 Ответы
Steven_L_Intel1
Сотрудник
1 026Просмотр.
Did the compilation of that module complete successfully? If you delete the .mod and rebuild, does the error recur? Have you been using this version of the compiler for a while? That is rather old at this point.
If the problem persists, get the most recent 8.1 (or 9.0 if possible) you're eligible for and try again.
nright
Начинающий
1 026Просмотр.
I got the same problem when using l_fc_p_9.0.021. The complilation options I used is :
/export/mpi/mpichgm_intel/bin/mpif90 -c -I/export/mpi/mpichgm_intel/include -ia32em -convert big_endian -O3 -w -DCPU_CLOCK -DPAPERLICENSE ../../../Source/Utility/comms.mpi.F90
The error message:
fortcom: Error: comms.mpi.F90, line 83: Error in opening the Library module file. [CONSTANTS]
use constants, only : dp
PS: There is no precompiled *.MOD.
tobias-burnus
Начинающий
1 026Просмотр.
Yes, the *.mod file looks ok (judging from `strings *.mod`) and it is well reproduceable.
No that is the first time I used it on that ia64.
(I used ifort 9.0 on the same program on a ia32 successfully.)
I'll ask the system administrators to do so.
Tobias
tobias-burnus
Начинающий
1 026Просмотр.
I think I found the cause of my problem. It is called Andrew File System (AFS). At least on the AFS it failed even with l_fc_c_9.0.032 whereas it workes just fine on a local disc (with the 8.1 and the 9.0).
(Frankly, I still don't understand why it fails on AFS; it mostly puzzles me that always the same file causes the trouble, the *.F shouldn't be a problem either since I copied them over. And with pgf90 it worked on the same AFS, albeit on a different computer.)
Tobias
Steven_L_Intel1
Сотрудник
1 026Просмотр.
Interesting. I don't recall seeing other customers with AFS issues, so I don't know what's going on here. The compiler uses standard C I/O calls to open and read modules.
Ответить
