"Find all reference" is not working in Visual Studio 2013
Z_L_
"Find all reference" is not working in Visual Studio 2013. The Fortran compiler version is 2013 SP1 Update2 and the OS is Windows 8.1 64bit.
Kevin_D_Intel
Can you please describe in more detail about what you tried that is not working?
It would even be more helpful and appreciated if you could attach a small reproducing solution/project that demonstrates the issue.
Z_L_
I tested many times and then find that "Find all reference" is not working only when there is a C++ project in the some solution with the Fortran project. Visual Studio 2012 has no this problem. The following file Example.zip is a reproducing solution.
Kevin_D_Intel
Thank you for the example. I conducted some testing with that as other solutions.
What sort of behavior are you witnessing?
I have not tested under Windows 8 yet, but under Window Server 2008 R2 when using VS2013, I experience hangs when attempting to use Find all References within the Fortran project of the mixed-language solution. The feature works within the C/C++ project of that mixed-language solution. The feature also works with an all Fortran solution or all C/C++ solution.
Steven_L_Intel1
I can reproduce this. Escalated as issue DPD200369926.
