29541 Discussions
"ICE: segmentation violation signal raised" with parameterized derived types
WileyOne
Compiler: ifx (IFX) 2025.2.1
OS: Rocky Linux 8.9 (Green Obsidian)
The latest version of the compiler exhibits an ICE with parameterized derived types. I'm fairly sure the code is valid, and the message requested that it be reported. Please see the attached code.
WileyOne
Confirmed that this was fixed with the 2026.0.0 release.
Ron_Green
it does look valid to me.  nagfor accepts this code.  gfortran 14.2 gets an ICE.  Even the nightly dev branch of ifx is getting an ICE with this.  I will create a bug report.  Thanks for sending this to us!
Ron_Green
The bug ID is CMPLRLLVM-70427. You had a similar report CMPLRLLVM-68773. This one we have a fix for just recently. It is in test phase. This new one could be related so I assigned it to the developer working on 68773. Hopefully this can be fixed in the same code she is working with for the older bug.
WileyOne
Thank you, Ron. Yes, this is similar to other issues I have recently reported, though none of them caused an ICE. I appreciate the update on CMPLRLLVM-68773; hopefully under the hood this is the same or a related problem that can be easily resolved.
Many thanks!
WileyOne
I lied - I completely forgot about another ICE I had previously reported. You were right!
Igor_V_Intel
The fix is implemented and will be available in the next major compiler release.
WileyOne
WileyOne
