This is a follow-up thread to this original thread: http://software.intel.com/en-us/forums/showthread.php?t=82265
"print OBJECT.ID" returns the same result as typing "whatis OBJECT.ID".
Same instance as before, I have a large structure with hundreds of variables, the last of which is a character string defined as:
CHARACTER*32 ID
When you type "p OBJECT(1).ID", the debugger returns:
type = character*32
Expected return would be the contents of the character string.
CHARACTER*32 ID
type = character*32
I can't reproduce what you are seeing with 'ID' - which version of the compiler (idb) are you using?
> idbc ./u82483
Intel Debugger for applications running on Intel 64, Version 12.0, Build [74.923.2]
object file name: ./u82483
Reading symbols from /nfs/var/quad/rwgreen/forums/u82483/u82483...done.
(idb) list 1,20
1 program confuse_an_idb
2 type con
3 character*32 :: a_cat
4 character*32 :: ID
5 end type con
6 type ( con ) :: confuse
7
8 confuse.a_cat = 'Royal confuse a cat team'
9 confuse.ID = 'Fluffy the spoiled house cat'
10
11 write(*,*) "break point here, ", confuse%ID
12
13 end program confuse_an_idb
(idb) break 11
Breakpoint 1 at 0x402bf5: file /nfs/var/quad/rwgreen/forums/u82483/u82483.f90, line 11.
(idb) run
Starting program: /nfs/var/quad/rwgreen/forums/u82483/u82483
[New Thread 47048430751808 (LWP 1340)]
Breakpoint 1, confuse_an_idb () at /nfs/var/quad/rwgreen/forums/u82483/u82483.f90:11
(idb) p confuse.id
$1 = "Fluffy the spoiled house cat "
(idb) p confuse.a_cat
$2 = "Royal confuse a cat team "
(idb)
> idbc ./u82483
(idb) list 1,20
2 type con
5 end type con
7
10
12
(idb) break 11
(idb) run
(idb) p confuse.id
(idb)
Hrm, when I create a standalone reproducer, I can't replicate the problem. However, it's consistently reproducable in my main application. I'll have to investigate this further to see if it's a compile flag I'm using, or something else non-debugger related.
Intel Debugger for applications running on IA-32, Version 12.0, Build [1.3842.2.154]
it could be context related also, assuming -g is used in the compilation. For example, we sometimes see idb problems with contained procedures, type-bound procedures, extended types. Context can sometimes trigger a bug.
Since it's returning the type information, I almost suspect -g was missed somewhere, but that's a total guess.
Ok, was finally able to reproduce it. The problem shows up when the program is linked with C++.
File 1: (Compile with 'ifort -g -c -assume nounderscore idb_test.for')
Finally, link the executable with "g++ -o idb_test -Wl,--start-group idb_test.o idb_test_cpp.o IFORTPATH/compiler/lib/ia32/libifport.a IFORTPATH/compiler/lib/ia32/libifcore.a IFORTPATH/compiler/lib/ia32/libimf.a IFORTPATH/compiler/lib/ia32/libirc.a IFORTPATH/compiler/lib/ia32/libirc_s.a -Wl,--end-group -lcurses", where IFORTPATH is the installation path of the Fortran compiler (in this instance version 12.0.1.107, Build 20101116).
We are linking using g++ because in our larger application there are mangled C++ routines which apparently must be linked using the g++ linker rather than the ifort linker to properly resolve the C++ libraries.
When you compile the C++ routine without debugging symbols (but with fortran debugging symbols), the debugger behaves as expected. When you compile the C++ routine with debugging symbols, the debugger produces the "type = character*32" behavior when examining OBJECT(1).ID as previously reported.
[bash] P R O G R A M I D B _ T E S T
C
IMPLICIT NONE
C
STRUCTURE /TEST_ARRAY/
INTEGER*4 NUM1
CHARACTER*32 ID
END STRUCTURE
C
RECORD /TEST_ARRAY/ OBJECT
INTEGER*4 NOBJS
COMMON /CTEST/ OBJECT(1000), NOBJS
C
NOBJS = 1
CALL CPP_ROUTINE
C
OBJECT(NOBJS).NUM1 = 10
OBJECT(NOBJS).ID = 'OBJECT_DESCRIPTION'
C
WRITE(*,*) 'EXAMINE HERE'
END[/bash] File 2: (Compile with 'g++ -c -g idb_test_cpp.cpp')[bash]#includeNote: The above should be "cout << ....", but the less than signs were mangled by the block quote.using namespace std; extern "C" void cpp_routine() { cout << " Running..."; return; }[/bash]
Sorry, forgot to mention g++ version is 4.3.2.
On Suse 11.4 X64, with Intel Fortran 12.0.3 (IA32 and Intel64), and g++/gcc 4.5.1, I cannot reproduce the problem, when both the Fortran and C++ parts are compiled with -g, and I stepped through the C++ source to verify that it had been compiled with -g.
A. In the "debugger commands" pane:
Breakpoint 1, idb_test () at /home/sham/LANG/idbp.f:20
20 WRITE(*,*) 'EXAMINE HERE'
(idb) p object(1)
$1 = {num1 = 10, id = "OBJECT_DESCRIPTION "}
(idb) p object(1).id
$2 = "OBJECT_DESCRIPTION "
(idb) whatis object(1).id
type = character*32
(idb)
B. In the evaluations pane:
OBJECT(1).ID 0x80b9b84 "OBJECT_DESCRIPTION " character*32
Can you try your example on a machine with a more recent g++ than 4.3.2 ?
(idb) p object(1)
type = character*32
(idb)
