29602 Discussions
"problem after compile code as parallel "
hamid_mosaddeghi
Hi Dear
I change module of code and insert some command but after compile this code work seq well but after compile parallel , don't work. and I get error.
in hint of some module "parallel replicated data version : block data" exist , what 's the meaning it?
for exmaple afetr run with 8 node ,I get error for 7 node :
cool region: -9.537 -7.803
hot region: 7.803 9.537
inital atoms: 24 28 6596
error! the atoms number in cool and hot region are incorrect 24 28
inital atoms: 0 0 6648
error! the atoms number in cool and hot region are incorrect 0 0
inital atoms: 34 16 6598
error! the atoms number in cool and hot region are incorrect 34 16
inital atoms: 31 22 6595
error! the atoms number in cool and hot region are incorrect 31 22
rank 6 in job 116 node12.phychem.iut_55559 caused collective abort of all ranks
exit status of rank 6: return code 0
rank 4 in job 116 node12.phychem.iut_55559 caused collective abort of all ranks
exit status of rank 4: killed by signal 9
rank 3 in job 116 node12.phychem.iut_55559 caused collective abort of all ranks
exit status of rank 3: killed by signal 9
rank 2 in job 116 node12.phychem.iut_55559 caused collective abort of all ranks
exit status of rank 2: killed by signal 9
what's your idea?
TimP
If your source code has more than one BLOCK DATA, or multiple references to the same variable or array in BLOCK DATA, that would explain the message. Some legacy applications depend on compilers which permitted such violations of standards, not always with predictable results (does the first or the last instance rule; will a second BLOCK DATA have any effect?).
If you added a data initialization on a variable or array which was already present in BLOCK DATA, that also would trigger such a complaint.
