"unable to open program xxxx"
clodxpro
Hi!
When is start debugging my code, under visual studio, i get the message "Unable to start program program_name.exe".
I saw other message like this occurr due to the visual studio service pack version, or due to the debugging mode issue.
But in my code there is a strange think. I allocated some arrays using a proper parameter to set their extent. Accordingly, as soon as i increase this parameter over a certain level, i get the error message, even if i have not reached the memory limit yet.
Does anyone has some suggestions??
Thank you
Claudio
Without knowing more details, I would guess that your total compile-time code and data size exceeded 2GB. Can you run the program normally (not under debug)?
