read multiple data
zxu4
I tried to read multiple data from one line in my datafile.
Data format is :
0.3,0.9,1.2,2.3
Comma is used to separate each of them, but I don't know how many in one line. I want to use an array to read all of them, like,
read(10,'(f5.2)')value(1),value(2),...
How to make it happen to my array value?
Thanks!
Roy
anthonyrichards
New Contributor III
Pasted from CVF help found using 'comma' in the 'Index':
Code:
Using Commas to Separate Input Data
You can use a comma to terminate a short data field.
The comma has no effect on the d part (the number of
characters to the right of the decimal point) of the specification. The comma overrides the w specified for the I, B, O, Z, F, E, D,
EN, ES, G, and L edit descriptors. For example, suppose the
following statements are executed: READ (5,100) I,J,A,B 100 FORMAT (2I6,2F10.2) Suppose a record containing the following values is read: 1, -2, 1.0, 35 The following assignments occur: I = 1 J = -2 A = 1.0 B = 0.35 A comma can only terminate fields less than w characters long.
If a comma follows a field of w or more characters, the comma
is considered part of the next field. A null (zero-length) field is designated by two successive
commas, or by a comma after a field of w characters. Depending
on the field descriptor specified, the resulting value assigned
is 0, 0.0, 0.0D0, 0.0Q0, or .FALSE..
