reading file
jaeger0
I have the following file format to read in:
PIXEL_SIZE = 1 mm THICKNESS_SLICES = 1 mm NUMBER_OF_SLICES = 101 IMAGE_DIMENSIONS = 57X57 pixels SLICES;SLICE Nr 1 0 0 1 1 0 0 1 0 0 0 0 0 0 0 1 1..
So I opened the file with OPEN(UNIT=file_id, FILE=filename, ACTION='READ', iostat=iErr)
I read out the image dimenstions, with read(file_id,*, iostat=iErr) line,dummy,Vimage%pixel_spacing(1),dummy2
Finally I would like to read out the image, as a sequence of 57X57 0,1
however, the normal rad call reads an entire line, not a single sign.
How can I manage this.
I think the read/write IO and formatting in Fortran is somewhat complicated !!
jimdempseyatthecove
Try reading the entire line into a character array
character(1024) :: InputLine
10 continue
read(iouin, 100, end = 999) InputLine
100 format(A1024)
if(InputLine .eq. ' ') goto 10 ! ignore blank line
! PIXEL_SIZE = 1 mm THICKNESS_SLICES = 1 mm NUMBER_OF_SLICES = 101 IMAGE_DIMENSIONS = 57X57 pixels SLICES;SLICE Nr 1 0 0 1 1 0 0 1 0 0 0 0 0 0 0 1 1..
Pixel_Size_Arg = RINDEX(InputLine, 'PIXEL_SIZE = ')
if(Pixel_Size_Arg .eq. 0) goto 888 ! error
read(InputLine(Pixel_Size_Arg:), *)Pixel_Size
SlicePos = RINDEX(InputLine, 'SLICE Nr ')
if(SlicePos .eq. 0) goto 888 ! error
InputLine = ADJUSTL(InputLine(SlicePos:))
do I=1,nPixels
read(InputLine,*) Pixel(I)
InputLine = ADJUSTL(InputLine(2:))
end do
Jim Dempsey
jaeger0
10 continue
100 format(A1024)
do I=1,nPixels
end do
Jim Dempsey
Thanks Jim,
I had that kind of solution in mind, but I hoped, there is an easier (more comfortable) way to do that.
jimdempseyatthecove
Well, if you use fixed column input and punched cards you might have better luck.
Kidding asside
If you do know that the input file has fixed field lengths you can declare a type with union
Example:
[cpp]    ! Variables
    type TypeInput
    union
    map
    character(132) :: InputLine
    end map
    map
    character :: Blank1
    character(6) :: AnnealTether
    end map
    map
    character(4) :: I4Field
    character(1) :: ws1
    character(16):: Value
    character(1) :: ws2
    character(110):: text
    end map
    map
    character :: Blank2
    character(13) :: DensityReset
    character(16):: DensityResetValue
    end map
    map
    character :: Blank3
    character(24) :: AdjustingBallastObject
    character(3) :: AdjustingBallastObjectNumber
    character(3) :: discard
    character(20):: AdjustingBallastObjectBallast
    end map
    end union
    end type TypeInput
[/cpp]
and declare an instance of the type
type(TypeInput) :: theInput
and in the program
[cpp]        READ(IOUIN, 100, end=999) theInput.InputLine
100     FORMAT(A132)
        if(theInput.DensityReset .eq. 'Reset Density') then
            ResetDensity = .true.
            READ(theInput.DensityResetValue, 201) ResetDensityValue
201         FORMAT(E9.6)
        endif
[/cpp]
etc...
Read the text from the file once, test data for what you expect, use read from variable to convert text to number.
Jim Dempsey
