hi,
i want to assign a real value for a spin. and so i will do some calculation.is that possible to change spin with a real interval, such a step that is 0.0004 ?
lret = DlgSetSub(dlg, IDC_SPIN1, Win3Spin)
lret = DlgSetSub(dlg, IDC_EDIT1, Win3Edit, DLG_LOSEFOCUS)
lret = DlgSet(dlg, IDC_SPIN1, 0.25)
lret = DlgSet(dlg, IDC_SPIN1, 0, DLG_RANGEMIN)
lret = DlgSet(dlg, IDC_SPIN1, 50, DLG_RANGEMAX)
SUBROUTINE Win3Spin( dlg, id, callbacktype )
real pos1
character*30 text1
if (callbacktype == dlg_change) then
status = dlgget(dlg, id, pos1)
write(text1, *) pos1
status = dlgset(dlg, IDC_EDIT1, text1)
endif
END SUBROUTINE Win3Spin
SUBROUTINE Win3Edit( dlg, id, callbacktype )
real pos1
character*30 text1
if (callbacktype == dlg_losefocus) then
status = dlgget(dlg, id, text1)
read(text1, *) pos1
status = dlgset(dlg, IDC_SPIN1, pos1)
endif
END SUBROUTINE Win3Edit
real pos1
character*30 text1
endif
real pos1
character*30 text1
read(text1, *) pos1
endif
Well... maybe, but not automatically. You can try the following code (untested). The idea is to read the contents of the edit control and add/subtract 0.004 manually, then write the contents back. To test whether the spin was moved up or down, the position is reset to the middle each time:
integer:: ipos, iErr
character*30:: text1
real:: pos, add
status = DlgGet(dlg, IDC_EDIT1, text1)
read(text1, *, IOSTAT=iErr) Pos
if (iErr.ne.0) pos = 0.
status = DlgGet(dlg, ID, iPos)
if (iPos < 25) then
Pos = Pos-0.04
else
Pos = Pos+0.04
end if
write(text1, *) pos
status = DlgSet(dlg, IDC_EDIT1, text1)
!Reset back to middle position
status = DlgGet(dlg, ID, 25)
endif
END SUBROUTINE Win3Spin[/pre]
Note that you'll lose the feature of "acceleration" of spin button (the longer you hold the button, the step increases).
Alternatively, you could try to convert your real range by multiplying/dividing by, say, 10**n. E.g. map range of allowed reals of (0.1...0.0001) into spin positions of (10000...1); each time the spin changes, divide its position by 10000. and set the edit control appropriately. However, if I recall correctly, the maximal allowed range of spin button is 65536 (but I'm not sure) so you can't cover wide ranges. Try it.
Jugoslav
real:: pos, add
if (iPos < 25) then
Pos = Pos-0.04
else
Pos = Pos+0.04
end if
write(text1, *) pos
endif
Jugoslav
hello again,
as you said i tried to divide/multiply the values when they overflow. for example i have a value that starts from 2e+12. and i want to put a spin control that will start from 1e+12 to 1e+14. so i did that code...
I'm lost. What's a spin?
Mike
Mike
A spin control has up and down buttons for selecting a number (usually displayed in an adjacent control.) For example, in a print dialog, the number of copies is usually a spin control.
Steve
Steve
dear steve,
if you know anything about my problem, could you help me? it is about putting exponential and real values in a spin control. check my win11 file, so you find where i need help. thank you...
Well, your example almost works -- you just have to use the same control as a storage, and add logic for up/down:
How you want the spin to behave is up to you. For example, you could increase the step if the value is bigger.
Note that your range is just about 1000. If I were you, I'd place a static box on the right side, wrote, "GHz" or "Giga" or "*10^12" or whatever, and place a normal edit box with integer value -- it is much more readable.
Jugoslav
SUBROUTINE Spin3( dlg, id, callbacktype )
use dflogm
use datas
implicit none
include 'resource.fd'
type (dialog) dlg
integer id, callbacktype
logical status
integer*4 iErr, iPos
character*20 text
real*4 pos
pos = na
status = DlgGet(dlg, IDC_EDIT3, text)
read(text, *, IOSTAT=iErr) pos
pos = pos / 1e+12
!Todo add logic to check min/max value.
if (iPos>50) then
pos = pos + 1
else if (iPos<50) then
pos = pos - 1
end if
status = DlgSet(dlg, ID, 50)
pos = pos * 1e+12
write(text, *) pos
status = DlgSet(dlg, IDC_EDIT3, text)
status = DlgSet(dlg, IDC_STATIC_NA, adjustl(text))
endif
END SUBROUTINE Spin3
Jugoslav
shiptar,
I don't know anything about this other than what a spin control is - I have never written code to use one. Jugoslav knows much more about dialog boxes than I do.
Steve
Steve
hi...
this morning i got your reply. i will try it,Jugoslavdujic. thank you again...
