reinstall v8.0 on red hat linux
Deleted_U_Intel
I'm trying to install v8.0 on the Red Hat Enterprise Linux WS (version3).
But, I got the following message.
--------------------------------------------------------------------------------Intel Fortran Compiler for 32-bit applications, Version 8.0
Installing...
This was already installed.
Installation failed.
What kind of rpm options do I need to reinstall ?
Unfortunately, I erased all the files in /opt/intel_fc_80 accidently.
TimP
If you change the rpm -U option to --force, you should be able to replace everything.
I normally run into this when going back to an earlier version. For that, there is an uninstall script in the installation.
gowda
To be precise replace the default rpm option of
"-U --replacefiles" with "-U --force".
Since I am new to RPM's, looking at tprince's reply I spent
half-an-hour replacing "-U" with "--force", which obviously
didn't work and had to look at the man page of rpm
to figure out that I had to replace it with "-U --force".
