29488 Discussions
relative ordering of LOGICAL and LOGICAL*1 in common blocks
jayb
As I've started several posts:  "I've got this legacy application . . ."
Among its many "remarkable" features is the use of LOGICAL*1 to store characters on occasion.  I will change those to CHARACTER as soon as the original author is ready is make that jump.  But for now, here is my puzzle.
The code does not pay much attention to alignment of common blocks, and Intel Fortran warns about this.   But it looks like the compiler wants LOGICAL to be placed before LOGICAL*1 even though (I think) the former takes up a bit, and the latter a byte.  A small example:
The following generates warnings:
      SUBROUTINE SOMETHING
      INTEGER INT1
      LOGICAL*1 BYTE1
      LOGICAL LOG1,LOG2
      COMMON /MY_COMMON/ INT1,BYTE1,LOG1,LOG2
      END
ddtest.for(4): remark #6375: Because of COMMON, the alignment of object is inconsistent with its type - potential performance impact.   [LOG1]
      LOGICAL LOG1,LOG2
ddtest.for(4): remark #6375: Because of COMMON, the alignment of object is inconsistent with its type - potential performance impact.   [LOG2]
      LOGICAL LOG1,LOG2
while the following is accepted:
      INTEGER INT1
      LOGICAL*1 BYTE1
      LOGICAL LOG1,LOG2
      COMMON /MY_COMMON/ INT1,LOG1,LOG2,BYTE1
      END
JayB
LOGICAL is 4 bytes, LOGICAL*1 is 1 byte. Fortran has no bit types.
The alignment warnings are for performance - you can disable them if they bother you by bracketing the COMMON with:
!DIR$ OPTIONS /WARN=NOALIGNMENT
!DIR$ END OPTIONS
In your second case, BYTE1 is at the end and therefore nothing is misaligned. The other variables in the COMMON are 4-bytes each.
