reshape not working
killjoy
I've been trying to resize a vector into a two dimensional array but at compile time I keep getting the same error message
Here is the program and the output
program prog2
integer::b(6)
b=(/ 1,2,3,4,5,6 /)
RESHAPE (b, (/2, 3/))
print 10, b
10 format (3(2X, I3))
end program prog2
# ifc -w reshape.f90 -o reshape
program PROG2
Error 395 at (4:reshape.f90) : This entity is not an array and must not be subscripted
1 Error
RESHAPE is a function, not a statement. The message is a bit obscure, but then again, the compiler was quite perplexed as to what you wanted.
CVF's message is essentially a syntax error...
You need to assign the result of RESHAPE to something, or use it in some context that requires an array.
Steve
killjoy
Thanks Steve, I'll figure out my bum from my head one of these days
