run time errors, stack size
hermannl
Does anyone know, whether the treatment of allocatable arrays and pointers has changed from ifort 9.1.040 to 9.1.041?
Dealing with large (allocatable) arrays, I observe segfaults in 9.1.041 where 9.1.040 ran without any problems. The segfault appears under the following circumstances:
i) a large arrayhas beensucessfully allocated an filled with data
ii) a copy of the array is to be stored by means of an allocatable array as follows:
first, the new array is allocated andallocation runs without problems
next, the array is to be copied (just as new_array = original_array)
in the second setp in ii) the segfault happens in 9.1.041, but not in 9.1.040!
It turned out that the segfault can be circumvented by do loops (do i=1,SIZE(original_array).....), increasing the stack size, or using the compiler option -heap-arrays. This optionI found mentioned by Steve in a reply to another post but have not been able to look-up in the compiler documentation. Any hint where to find it?
Hermann
Not that I am aware of. 9.1.041 has improvements in the elmination of unnecessary stack temps, however. The switch you are looking for is -heap-arrays and is described in the release notes.
I would ask that you submit a test case to Intel Premier Support, as a program which worked in 9.1.040 and doesn't in 041 could mean a compiler bug.
hermannl
Dear Steve,
thanks for mentioning the release notes - I missed that!
Regarding the test case - I will do my very best. I already tried to reduce the problem, however, up to now I did not succeed: the problem only shows up in the complete program (some 100.000 lines of code), reduction to a few lines is still missing.
Hermann
We'll take the whole program if you find reducing it difficult.
hermannl
Hi Steve,
I could reduce the problem to a few lines and reported that to premier support as you suggested. As it turned out, the problem stemmed actually from a bug fix in9.1.041. Therefore, the segfault did not occurin 9.1.040.
At the moment, the best solution for meseems to be the use of the heap-arrays flag,which works under Linux and Windows as well.
Best, Hermann
Right - the developer came over and told me what was happening. In previous versions, the compiler was skipping the check for potential overlap in an assigmnent such as:
a%b = c
where either b or c was a POINTER. This could result in incorrect behavior if the pointers overlapped. Now it realizes that it can't tell if there is an overlap and creates a temp. You can avoid the problem by using ALLOCATABLE instead of POINTER because the semantics of the language do not allow for different ALLOCATABLEs to overlap.
hermannl
Hi Steve,
the "problem" with allocatable arrays, in the specific case here, is that the arrays are components of a user defined (matrix) type. As far as I know, the use of allocatable arrays in this context conflicted with the FORTRAN 90 and 95 standards (and, as far as I remember, caused compilation failure of the corresponding program unit with former Intel Fortran compilers). I just checked the Fortran 2003 standard, and things seems to have changed. Also Icompiled a simple test example (only specification of the matrix type) using allocatable arrays as type components and it seems to work. SoI guessthatIntel Fortran 9.1.xxx does support this Fortran 2003 feature- which is good news for me.
Best,
Hermann
Yes, allocatable components of a derived type is a F2003 feature but is one that has been supported in Intel Fortran since version 8.0 and is also supported by most other F95 compilers on the market.
