29418 Discussions
running intel fortran on a macOS BigSur (version 11.7.6)
metzgeriana
I have been working on atom-in-molecule polarizabilities using CNDOP, a program much modified  from CNINDO (CNINDO was first written about 1970 by Paul Dobosch in the group of John A. Pople). I am using a Mac laptop (MacOS Big Sur  version 11.7.6).
Intel keeps improving its Fortran. It used to have a messy library call for the run-time Fortran program library. Instead, to provide automatic access from the FORTRAN compiler to the library, I installed oneAPI HPB Toolkit (version 2023.1) inter-oneapi-ifort-runtime-2023.1.0.43547, and then installed ifort (version of March 2023).
A simple numbering program num.FOR was written to
(i) access a short data set, called CNI.txt with alphanumeric text written by Microsoft Word, with margins set between columns 1 and 72 (old Hollerith “IBM” card convention) and FORTRAN commands entered between  column 7 and 72, and statement numbers entered between column 1 on 5, and comment cards designated as a comment by a “C” in column 1.
(ii)  copy the lines of CNI.txt one at time and place them into file FOR.06, but append “CNI” in columns 73,74, and 75, and line numbers right-justified in columns 76 to 80.
BEG 1 = = = = = FORTRAN program num.FOR
C234567
      CHARACTER*1 A(72)
      LINPUT=05
      OPEN (UNIT=5,FILE='desktop/CNI.txt',STATUS='OLD')
      LOUTPT=06
      OPEN (UNIT=6,FILE='desktop/FOR.06',STATUS='REPLACE')
      DO 4 I=1,500
         READ (LINPUT,1) (A(K),K=1,72)
    1    FORMAT (72A1)
         WRITE (LOUTPT,2) I
    2    FORMAT (' READING LINE NUMBER',I5)
         WRITE (LOUTPT,3) (A(K),K=1,72),I
    3    FORMAT (72A1,'CNI',I5)
    4 CONTINUE
    5 STOP
      END
END 1 = = = = = FORTRAN program num.FOR
The  input data (file CNI.txt) are:
BEG  2  = = = = = data file CNI.txt
             BLOCK DATA
             COMMON/ORB/ORB(9)
             COMMON/PERTBL/EL(18)
             COMMON /OPTION/OPTION,OPNCLO,HUCKEL,CNDO,I NDO,CLOSED,OPEN
             INTEGER OPTION,OPNCLO,HUCKEL,CNDO,INDO,CLOSED,OPEN
             INTEGER ORB,EL
             DATA CNDO/'CNDO'/
             DATA INDO/'INDO’/
             DATA OPEN/’OPEN'/
             DATA CLOSED/’CLSD'/
             DATA ORB/’  S’,'  PX','  PY','  PZ',' DZ2',' DXZ’,’ DYZ','DX-Y',
           1' DXY’/
C234567
             DATA EL/’  H’,’  HE’,’  LI’,’  BE’,’   B’,’   C’,’   N’,’   O’,
  •    ’   F’,’  NE’,’  NA’,’  MG’,’  AL’,’  SI’,’   P’,’   S’,
     2      ’  CL’,’  AR’/
             END
C           PROGRAM CNINDO
             IMPLICIT REAL*8(A-H,O-Z)
             COMMON/ARRAYS/ABC(19200)
             COMMON/INFO/NATOMS,CHARGE,MULTIP,AN(39),C(35,3),N
             COMMON /PERTBL/EL(18)
             COMMON /ORB/ORB(9)
             COMMON/GAB/XYZ(2000)
             COMMON/INFO1/CZ(35),U(80),ULIM(35),LLIM(35),NELECS,OCCA,OCCB
             COMMON /OPTION/OPTION,OPNCLO,HUCKEL,CNDO,INDO,CLOSED,OPEN
             COMMON /AUXINT/A(17),B(17)
             INTEGER ORB,EL,AN,CHARGE,CZ,U,ULIM,OCCA,OCCB
C          INPUT IS READ IN THE  FOLLOWING ORDER
C     (1) AN IDENTIFICATION CARD WH!CH 1s PRINTED AT THE BEGINNING OF THE RUN
C     (2) OPTION (WAVE FUNCTION OPTION) AND OPNCLO(OPEN OR CLOSED SHELL)
C          THE FORMAT IS A4,1X,A4 AND THE KEY WORDS ARE·-
  1.            FOR THE WAVEVUNCTON (A4)    CNDO    INOO
  2.             FOR THE OPEN-CLOSED OPTION (A6)     OPEN  CLSD
C      (3) NATOMS, CHARGW, MULTI    FORMAT (3I4)
C     (4) ATOMIC NUMBER, X COORDINATE, Y COORDINATE, Z COORDINATE - 1 CARD/ATOM
C          FORMAT(l4,3(3X,F12.7)
C*****************************************************************************
           LINPUT=05
           OPEN (UNIT=LINPUT,FILE='desktop/cni.DAT',STATUS='OLD')
            LOUTPT=06
            OPEN (UNIT=LOUTPT,FILE='desktop/FOR.06',STATUS='REPLACE')
C--------CALL DATE AND TIME: DATE COMES AS YYYYMMDD;-----------------------
C         TIME COMES AS HHMMSS.SSS
             CALL DATE_AND_TIME (B(1),B(2),B(3),DATE_TIME)
             WRITE (LOUTPT,1) LINPUT,LOUTPT, B(1),B(2)
          1 FORMAT (' CNINDO (QCPE 141- UPDATED 23 APR 2023)'/
           1' R.M.METZGER, UNIV. OF ALABAMA'/' ',65('-')/
           2' CARD READER  INPUT  ON FORTRAN LOGICAL LINPUT=',I3/
          3' LINE PRINTER OUTPUT ON FORTRAN LOGICAL LOUTPT=',I3/
          4' (PARTIAL ALPHA RUNS)'/' ',69('-')/' DATE (FORMAT:YYYYMMDD)=',
          5 A8,' TIME (FORMAT:HHMMSS.SSS)=',A10/' ',69('-'))
             READ (5,20) (AN(I),I=1-20)
             WRITE (6,30) (AN(I0,i=1.20)
             READ (5,40) OPTION,OPNCLO
             WRITE (6,45) OPTION,OPNCLO
              READ (5,50) NATOMS,CHARGE,MULTIP
              WRITE (6,60) NATOMS,CHARGE,MULTIP
             DO 10 I =1,NATOMS
                   READ(5,70) AN(l),C(I,1),C(I,2),C(I,3)
                  WRITE(6,70) AN(l),C(l,I),C(I,2),C(I,3)
C              CONVERSION OF COORDINATES RROM ANGSTROMS TO ATOMIC UNITS
                 DO 9 J=1,3
         9      C(I,J)= C(I,J)/0.529167D0
       10 CONTINUE
             IF (OPTION.EQ.CNDO) GO TO  6
     1     DO 5 I= 1,NATOMS
                 IF (AN(I).LE.9) GO TO  4
     2          WRITE (6,3)
     3          FORMAT(5X,46HTHIS PROGRAM DOES NOT DO INDO CALCULATIONS FOR,
       1         51H MOLECULES CONTAINING ELEMENTS HIGHER THAN FLUORINE)
                STOP
       4   CONTINUE
       5   CONTINUE
       6  CONTINUE
            CALL COEFFT
            CALL INTGRL
           IF (OPNCLO.EQ.OPEN) GO TO 90
   80     CALL HUCKCL
            CALL SCFCLO
            CALL CPRINT
           GO TO 100
     90  CALL HUCKOP
           CALL SCFOPN
            CALL OPRINT
    100 CONTINUE
     20 FORMAT(20A4)
     30 FORMAT(1H1,5X,20A4)
     40 FORMAT(A4,1X,A4)
     45 FORMAT(5X,A4,1X,A4)
     50 FORMAT(3I4)
     60 FORMAT(/5X,l4,’ATOMS   CHARGE=’,I4,  MULTIPLICITY’_MUU
    70 FORMAT(I4,3(3X,F12.7
          CALL EXIT
          STOP
         END
END 2 = = = = = = = of data set CNI.txt
The command lines in Terminal are:
BEG 3 = = = = =
ifort desktop/num.FOR -o desktop/num.exe
exec desktop/num.exe
END 3= = = = =
The results on Terminal are:
BEG 4 = = = = = entries in Terminal (in red: my input)
Last login: Tue May 16 07:10:48 on ttys000
robertmetzger@Roberts-MBP ~ % ifort desktop/num.FOR -o desktop/num.exe
robertmetzger@Roberts-MBP ~ % exec desktop/num.exe
forrtl: severe (24): end-of-file during read, unit 5, file /Users/robertmetzger/desktop/CNI.txt
Image              PC                Routine            Line        Source
num.exe            00000001066D754B  for__io_return        Unknown  Unknown
num.exe            00000001066F8EAC  for_read_seq_fmt      Unknown  Unknown
num.exe            00000001066BFCB8  MAIN__                Unknown  Unknown
num.exe            00000001066BFB6E  main                  Unknown  Unknown
[Process completed]
END 4 = = = = = of entries in Terminal (in red: my input)
The output on FOR.06 is:
BEG 5 = = = = = = = output file FOR.06
READING LINE NUMBER    1
  BLOCK DATA
  COMMON/ORB/ORB(9)
  COMMON /OPTIONCNI    1
 READING LINE NUMBER    2
        CNI    2
 READING LINE NUMBER    3
      COMMON/ARRAYS/ABC(19200CNI    3
END 5 = = = = = = = of output file FOR.06
Clearly the FORTRAN instructions are not carried out correctly...... AM I MISSING SOME ESSENTIAL LIBRARY ROUTINES?
Why do  some lines of the input file CNI.txt reproduce on output file FOR.06, but without title “CNI” and line numbers past column 72?
Am I foolish to insist one command-line mode, instead of Micsrosoft Visual Basic mode?
HELP !!!!
Ron_Green
please attach your files.  Cut and paste from a web post adds spaces, newlines, etc.
