- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
I have been working on atom-in-molecule polarizabilities using CNDOP, a program much modified from CNINDO (CNINDO was first written about 1970 by Paul Dobosch in the group of John A. Pople). I am using a Mac laptop (MacOS Big Sur version 11.7.6).
Intel keeps improving its Fortran. It used to have a messy library call for the run-time Fortran program library. Instead, to provide automatic access from the FORTRAN compiler to the library, I installed oneAPI HPB Toolkit (version 2023.1) inter-oneapi-ifort-runtime-2023.1.0.43547, and then installed ifort (version of March 2023).
A simple numbering program num.FOR was written to
(i) access a short data set, called CNI.txt with alphanumeric text written by Microsoft Word, with margins set between columns 1 and 72 (old Hollerith “IBM” card convention) and FORTRAN commands entered between column 7 and 72, and statement numbers entered between column 1 on 5, and comment cards designated as a comment by a “C” in column 1.
(ii) copy the lines of CNI.txt one at time and place them into file FOR.06, but append “CNI” in columns 73,74, and 75, and line numbers right-justified in columns 76 to 80.
BEG 1 = = = = = FORTRAN program num.FOR
C234567
CHARACTER*1 A(72)
LINPUT=05
OPEN (UNIT=5,FILE='desktop/CNI.txt',STATUS='OLD')
LOUTPT=06
OPEN (UNIT=6,FILE='desktop/FOR.06',STATUS='REPLACE')
DO 4 I=1,500
READ (LINPUT,1) (A(K),K=1,72)
1 FORMAT (72A1)
WRITE (LOUTPT,2) I
2 FORMAT (' READING LINE NUMBER',I5)
WRITE (LOUTPT,3) (A(K),K=1,72),I
3 FORMAT (72A1,'CNI',I5)
4 CONTINUE
5 STOP
END
END 1 = = = = = FORTRAN program num.FOR
The input data (file CNI.txt) are:
BEG 2 = = = = = data file CNI.txt
BLOCK DATA
COMMON/ORB/ORB(9)
COMMON/PERTBL/EL(18)
COMMON /OPTION/OPTION,OPNCLO,HUCKEL,CNDO,I NDO,CLOSED,OPEN
INTEGER OPTION,OPNCLO,HUCKEL,CNDO,INDO,CLOSED,OPEN
INTEGER ORB,EL
DATA CNDO/'CNDO'/
DATA INDO/'INDO’/
DATA OPEN/’OPEN'/
DATA CLOSED/’CLSD'/
DATA ORB/’ S’,' PX',' PY',' PZ',' DZ2',' DXZ’,’ DYZ','DX-Y',
1' DXY’/
C234567
DATA EL/’ H’,’ HE’,’ LI’,’ BE’,’ B’,’ C’,’ N’,’ O’,
- ’ F’,’ NE’,’ NA’,’ MG’,’ AL’,’ SI’,’ P’,’ S’,
2 ’ CL’,’ AR’/
END
C PROGRAM CNINDO
IMPLICIT REAL*8(A-H,O-Z)
COMMON/ARRAYS/ABC(19200)
COMMON/INFO/NATOMS,CHARGE,MULTIP,AN(39),C(35,3),N
COMMON /PERTBL/EL(18)
COMMON /ORB/ORB(9)
COMMON/GAB/XYZ(2000)
COMMON/INFO1/CZ(35),U(80),ULIM(35),LLIM(35),NELECS,OCCA,OCCB
COMMON /OPTION/OPTION,OPNCLO,HUCKEL,CNDO,INDO,CLOSED,OPEN
COMMON /AUXINT/A(17),B(17)
INTEGER ORB,EL,AN,CHARGE,CZ,U,ULIM,OCCA,OCCB
C INPUT IS READ IN THE FOLLOWING ORDER
C (1) AN IDENTIFICATION CARD WH!CH 1s PRINTED AT THE BEGINNING OF THE RUN
C (2) OPTION (WAVE FUNCTION OPTION) AND OPNCLO(OPEN OR CLOSED SHELL)
C THE FORMAT IS A4,1X,A4 AND THE KEY WORDS ARE·-
- FOR THE WAVEVUNCTON (A4) CNDO INOO
- FOR THE OPEN-CLOSED OPTION (A6) OPEN CLSD
C (3) NATOMS, CHARGW, MULTI FORMAT (3I4)
C (4) ATOMIC NUMBER, X COORDINATE, Y COORDINATE, Z COORDINATE - 1 CARD/ATOM
C FORMAT(l4,3(3X,F12.7)
C*****************************************************************************
LINPUT=05
OPEN (UNIT=LINPUT,FILE='desktop/cni.DAT',STATUS='OLD')
LOUTPT=06
OPEN (UNIT=LOUTPT,FILE='desktop/FOR.06',STATUS='REPLACE')
C--------CALL DATE AND TIME: DATE COMES AS YYYYMMDD;-----------------------
C TIME COMES AS HHMMSS.SSS
CALL DATE_AND_TIME (B(1),B(2),B(3),DATE_TIME)
WRITE (LOUTPT,1) LINPUT,LOUTPT, B(1),B(2)
1 FORMAT (' CNINDO (QCPE 141- UPDATED 23 APR 2023)'/
1' R.M.METZGER, UNIV. OF ALABAMA'/' ',65('-')/
2' CARD READER INPUT ON FORTRAN LOGICAL LINPUT=',I3/
3' LINE PRINTER OUTPUT ON FORTRAN LOGICAL LOUTPT=',I3/
4' (PARTIAL ALPHA RUNS)'/' ',69('-')/' DATE (FORMAT:YYYYMMDD)=',
5 A8,' TIME (FORMAT:HHMMSS.SSS)=',A10/' ',69('-'))
READ (5,20) (AN(I),I=1-20)
WRITE (6,30) (AN(I0,i=1.20)
READ (5,40) OPTION,OPNCLO
WRITE (6,45) OPTION,OPNCLO
READ (5,50) NATOMS,CHARGE,MULTIP
WRITE (6,60) NATOMS,CHARGE,MULTIP
DO 10 I =1,NATOMS
READ(5,70) AN(l),C(I,1),C(I,2),C(I,3)
WRITE(6,70) AN(l),C(l,I),C(I,2),C(I,3)
C CONVERSION OF COORDINATES RROM ANGSTROMS TO ATOMIC UNITS
DO 9 J=1,3
9 C(I,J)= C(I,J)/0.529167D0
10 CONTINUE
IF (OPTION.EQ.CNDO) GO TO 6
1 DO 5 I= 1,NATOMS
IF (AN(I).LE.9) GO TO 4
2 WRITE (6,3)
3 FORMAT(5X,46HTHIS PROGRAM DOES NOT DO INDO CALCULATIONS FOR,
1 51H MOLECULES CONTAINING ELEMENTS HIGHER THAN FLUORINE)
STOP
4 CONTINUE
5 CONTINUE
6 CONTINUE
CALL COEFFT
CALL INTGRL
IF (OPNCLO.EQ.OPEN) GO TO 90
80 CALL HUCKCL
CALL SCFCLO
CALL CPRINT
GO TO 100
90 CALL HUCKOP
CALL SCFOPN
CALL OPRINT
100 CONTINUE
20 FORMAT(20A4)
30 FORMAT(1H1,5X,20A4)
40 FORMAT(A4,1X,A4)
45 FORMAT(5X,A4,1X,A4)
50 FORMAT(3I4)
60 FORMAT(/5X,l4,’ATOMS CHARGE=’,I4, MULTIPLICITY’_MUU
70 FORMAT(I4,3(3X,F12.7
CALL EXIT
STOP
END
END 2 = = = = = = = of data set CNI.txt
The command lines in Terminal are:
BEG 3 = = = = =
ifort desktop/num.FOR -o desktop/num.exe
exec desktop/num.exe
END 3= = = = =
The results on Terminal are:
BEG 4 = = = = = entries in Terminal (in red: my input)
Last login: Tue May 16 07:10:48 on ttys000
robertmetzger@Roberts-MBP ~ % ifort desktop/num.FOR -o desktop/num.exe
robertmetzger@Roberts-MBP ~ % exec desktop/num.exe
forrtl: severe (24): end-of-file during read, unit 5, file /Users/robertmetzger/desktop/CNI.txt
Image PC Routine Line Source
num.exe 00000001066D754B for__io_return Unknown Unknown
num.exe 00000001066F8EAC for_read_seq_fmt Unknown Unknown
num.exe 00000001066BFCB8 MAIN__ Unknown Unknown
num.exe 00000001066BFB6E main Unknown Unknown
[Process completed]
END 4 = = = = = of entries in Terminal (in red: my input)
The output on FOR.06 is:
BEG 5 = = = = = = = output file FOR.06
READING LINE NUMBER 1
BLOCK DATA
COMMON/ORB/ORB(9)
COMMON /OPTIONCNI 1
READING LINE NUMBER 2
CNI 2
READING LINE NUMBER 3
COMMON/ARRAYS/ABC(19200CNI 3
END 5 = = = = = = = of output file FOR.06
Clearly the FORTRAN instructions are not carried out correctly...... AM I MISSING SOME ESSENTIAL LIBRARY ROUTINES?
Why do some lines of the input file CNI.txt reproduce on output file FOR.06, but without title “CNI” and line numbers past column 72?
Am I foolish to insist one command-line mode, instead of Micsrosoft Visual Basic mode?
HELP !!!!
Enlace copiado
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
please attach your files. Cut and paste from a web post adds spaces, newlines, etc.
- Marcar tema como nuevo
- Marcar tema como leído
- Favorito
- Suscribir
