29415 Discussions
runtime error: forrtl: severe (174): SIGSEGV, segmentation fault occurred
prashant98
Hi guys!
I am trying to compile my code and i get the following error during RUNTIME. The code compiles successfully without any warnings and when i run it i get the output but in the end the following error pops up:
I tried using the option -traceback and found out the location of the errors but i can't understand what's the problem at those line numbers.
Can somebody suggest me something.
Ron_Green
On this Forum homepage, there is a blue title bar with a pull down for "Search Forum" and enter "SIGSEGV" for your search string. You will find many many threads on this generic error.
ron
