29487 Discussions
saving common variables, Fortran Compiler 9.0, VS2003 Standard, w/Vista
cfann61
After compiling in Win98, and transitioning to XP, I found that some of the subroutines needed a SAVE to keep common variables. I am now using Vista, and I believe more subroutines need the SAVE function. Should I put a SAVE in all subroutines or is there a global property I can set to do this for me?
Hmm - 9.0 is not supported on Vista and neither is VS2003. Nevertheless, our implementation always treats COMMON as SAVE. My guess is that you have not properly identified the cause of the problem you're seeing.
