29416 Discussions
seg fault in parallel loop using a common block variable in call - depends on ifort version
hallevison
Hi:
I am getting a sef fault that I do not understand.  Perhaps the best thing is to show you the structure of the code.
[fortran]
     integer i
     real*8 rfblow,rfbhi,drfb,rsmall(NTPMAX),vrelv,mass(NTPMAX)
     real*16 rsmall16(NTPMAX),ratq,rsmr16
      common/c_rsm/rfblow,rfbhi,drfb,rsmall,rsmall16
[/fortran]
later
[fortran]
!$OMP    PARALLEL DO SCHEDULE(DYNAMIC) DEFAULT(NONE)
!$OMP&      PRIVATE(i,rsmr16,vrelv,ratq)
!$OMP&      SHARED(rsmall16,mass)
      do i=2,nbod
[/fortran]
later in the same loop
[fortran]
                     write(*,*) 'Here #C0.1',i
                     write(*,*) 'Here #C0.3',rsmr16
                     write(*,*) 'Here #C0.2',rsmall16(i)
                     write(*,*) 'Here #C0.4',vrelv
                     write(*,*) 'Here #C0.5',mass(i)
                     write(*,*) 'Here #C0.6',ratq
                     call size_qstarrat(i,rsmall16(i),rsmr16,vrelv,
     &                    mass(i),ratq)
[/fortran]
Then I have the subroutine
[fortran]      subroutine size_qstarrat(id,rtarg,rimp,vrel2,mtr,ratq)
      integer id
      real*8 vrel2,mtr,grnd_MT,tglob
      real*16 rtarg,rimp,dcomet16,ratq
      real*16 qcap,qstar,qstarcgs,rtargcm
      real*16 ratm,pdis,ratmlr,ratmf
      real*16 mtarg,mimp,mnew,rnew
c-----
c...  Executable code
      write(*,*) 'Here #Q0.1',id
      write(*,*) 'Here #Q0.2',rimp
      write(*,*) 'Here #Q0.3',rtarg
      write(*,*) 'Here #Q0.4',vrel2
      write(*,*) 'Here #Q0.5',mtr
      write(*,*) 'Here #Q0.6',ratq
[/fortran]
The output when I run it looks like:
 Here #C0.1           6
 Here #C0.3  1.337014580143983178473131948054959E-0012
 Here #C0.2  7.797292446069711940208707975960478E-0007
 Here #C0.4  1.039694216870462E-002
 Here #C0.5  1.185758329154166E-006
 Here #C0.6  0.000000000000000000000000000000000E+0000
 Here #Q0.1           6
 Here #Q0.2  1.337014580143983178473131948054959E-0012
forrtl: severe (174): SIGSEGV, segmentation fault occurred
Image              PC                Routine            Line        Source
stryAJtmp          00000000004215A9  size_qstarrat_           4438  stryAJtmp.f
stryAJtmp          000000000041C432  col_disk_                1987  stryAJtmp.f
libiomp5.so        00002AC0E7BE4073  Unknown               Unknown  Unknown
In other words, I get a seg fault when I try to access rtarg in the subroutine.  This is rsmall16(i) in the main routine which prints out fine before the call (it is #c0.2).  So, for some reason the subroutine is not getting  the address correct address for rsmall16(i).  Note that rsmall16(i) is part of a common block, but the subroutine does not know about that.  I need to keep it that way because I use the subroutine other places when the input is not part of the common block.
I should note that I have several machines with different versions of ifort.  The machines with version 11.1 20100414
 DO NOT HAVE THIS PROBLEM, but my machines with version 12.1.3 20120212 and  13.0.0 20120731 do.
I am compiling it with:
 ifort -mcmodel=medium -i-dynamic -heap-arrays -openmp -fpe0 -traceback -w -recursive -o stryAJtmp stryAJtmp.f -L/usr/local/lib/ -L/home/hal/lib/ -I/home/hal/SWIFT_P/ -L/home/hal/SWIFT_P/ -lswift -lfxdr -lMT_rand_OMP
and my libraires are also compiled with these flags.  Also, I have KMP_STACKSIZE=64m and OMP_NUM_THREADS 1
I tried to reproduce the problem with a simple code:
[fortran]
      real*16 x(100)
      common/c_test/x
      do i=1,100
         x(i) = i
      enddo
!$OMP&      PRIVATE(i)
!$OMP&      SHARED(x)
      do i=1,100
         call sub(x(i))
      enddo
!$OMP END PARALLEL DO
      stop
      end
c---
      subroutine sub(x)
      real*16 x
      write(*,*) x
      return
      end
[/fortran]
but, unfortunately, this worked fine.
Thanks for any insight that you can give me.
hallevison
Hi: I have been able to make this particular instance of the problem go away if I replace the subroutine call with [fortran] rifort16 = rsmall16(i) ! needed to get around ifort problem call size_qstarrat(i,rifort16,rsmr16,vrelv, & mass(i),ratq) [/fortran] But that just moves the issue to the next place where I use rsmall16 as a input parameter for a subroutine. Interestingly, only rsmall16 seems to be a problem despite the fact that I use other arrays from common blocks in calls.
