29348 Discussions
segfaults with iso_c_binding (inconsistent data sizes?)
AlexRichert-RedLine
With ifx, I am seeing segfaults that I don't get with other compilers when using a C-based executable to call a Fortran function defined through bindings. The following is the Fortran code defining the C function:
module bufr_c2f_interface
use iso_c_binding
implicit none
private
public :: ibfms_c
contains
function ibfms_c(r8val) result(ires) bind(C, name='ibfms_f')
real(c_double), intent(in), value :: r8val
integer(c_int) :: ires
integer :: ibfms
ires = ibfms(r8val)
end function ibfms_c
end module bufr_c2f_interface
 The following is the definition of the 'ibfms' Fortran function (modv_bmiss provides the BMISS variable, that's it):
INTEGER FUNCTION IBFMS ( R8VAL )
USE MODV_BMISS
REAL*8 R8VAL
IF ( R8VAL .EQ. BMISS ) THEN
IBFMS = 1
ELSE
IBFMS = 0
ENDIF
RETURN
END
 Here is main() from the C code calling the 'ibfms_f' function:
int main() {
int jj;
double r8arr[180][15];
for ( jj = 0; jj < 11; jj++ ) {
r8arr[0][jj] = 1.0;
if ( ibfms_f( r8arr[0][jj] ) ) {
printf( "%s\n", "ibfms check FAILED!" );
exit(1);
 The segfault happens when it attempts to access R8VAL in the 'IF ( R8VAL .EQ. BMISS ) THEN' line:
(gdb) bt
#0 0x000000000040487b in ibfms (r8val=<error reading variable: Cannot access memory at address 0x1>) at /n/NCEPLIBS_CI_Updates_Nov2023/bufrtestcaseoneapi/src/ibfms.f:34
#1 0x0000000000404770 in main () at /n/NCEPLIBS_CI_Updates_Nov2023/bufrtestcaseoneapi/test/test_c_interface_2.c:13
I can resolve the segfault by modifying ibfms_f, changing 'ires = ibfms(r8val)' to 'ires = ibfms(real(r8val,kind=8))', but this doesn't make sense to me, because ostensibly 'c_double' and 'real*8' should be the same size. Am I missing something? For what it's worth, I tested building the Fortran component with ifort and the C component still with icx, and that resolved it, so whatever the difference between compilers is, I'm fairly certain it's something on the Fortran side. I have tried this with a couple of ifx versions including 2024.0 and they all give the same behavior.
Barbara_P_Intel
Can you please provide the module MODV_BMISS and anything it depends on?
AlexRichert-RedLine
Here's the module definition (no further dependencies):
module modv_bmiss
!> Current placeholder value to represent "missing" data when reading
!> from or writing to BUFR files; this value can be changed at any
!> time via a call to subroutine setbmiss().
real*8, public :: BMISS = 10E10_8
end module modv_bmiss
Barbara_P_Intel
Thank you for that Fortran module.
That C mainline doesn't compile. I could try to fix it, but I may not do what you intend. Can you please update it?
Are you using any special compiler options?
AlexRichert-RedLine
Sorry for not providing a complete setup, I'll do so here:
Build steps:
export CC="icx -g -traceback"
export FC="ifx -g -traceback"
${FC:?} -c ibfms.f -o ibfms.o
${FC:?} -c bufr_c2f_interface.F90 -o bufr_c2f_interface.o
/usr/bin/rm -f libbufr.a
/usr/bin/ar qc libbufr.a ibfms.o bufr_c2f_interface.o
${CC:?} -c test_c_interface_2.c -o test_c_interface_2.c.o
${CC:?} test_c_interface_2.c.o -o test_c_interface.x libbufr.a
# Expected segfault:
./test_c_interface.x
#include <stdio.h>
#include <stdlib.h>
int ibfms_f(double r8val);
int main() {
int jj;
r8arr[0][jj] = 1.0;
exit(1);
bufr_c2f_interface.F90:
use iso_c_binding
implicit none
private
public :: ibfms_c
contains
integer :: ibfms
ires = ibfms(r8val)
ibfms.f:
REAL*8 :: BMISS = 10E10_8
REAL*8 R8VAL
IBFMS = 1
ELSE
IBFMS = 0
ENDIF
RETURN
END
Barbara_P_Intel
Thank you for all the details, @AlexRichert-RedLine! I filed a bug report, CMPLRLLVM-54110, We'll let you know its progress to a fix.
Barbara_P_Intel
One of the Fortran compiler team members has a workaround for you.
use iso_c_binding
implicit none
private
public :: ibfms_c
contains
!integer :: ibfms
interface
    integer function ibfms(a)
        use iso_c_binding
        real(c_double), intent(in) :: a
    end function
end interface
ires = ibfms(r8val)
AlexRichert-RedLine
Thanks Barbara. Do you have a sense yet of how far off a fix to the compiler might be? For the moment it's not out of the question to wait for a fix in order to keep the code clean (we have a fair number of these cases in our code).
Barbara_P_Intel
Sorry, I don't have an estimate as to when the fix will be available. I don't know how complicated the implementation is.
AlexRichert-RedLine
Do we have any update on the progress of this issue?
Barbara_P_Intel
The compiler engineer reports that the fix is in review.
I don't know if will make the code cutoff for 2024.2 which is next week. (fingers-crossed)
Barbara_P_Intel
This issue with iso_c_binding is fixed in the 2024.2 compiler. This release is planned for mid-2024.
