29578 Discussions
segmentation fault installing Fortran compiler version 11.1 update 8 on Linux
Edmund_Sumbar
Installation of Intel Fortran compiler 11.1 update 8 aborts during step 4 after selecting a custom install (necessary to specify a custom installation directory).
During the custom install procedure, I select "Full" (default) and "RPM" (default), but then after selecting menu option "2" to enter a custom install directory, the script does not prompt to enter a path. However, when I enter a path, the script eventually seg faults.I get the same behaviour with both the ia-32/intel64 tarball and the intel64-only tarball. Anyone have any ideas how to work around this, or is it a bug.
Ed
Step no: 4 of 7 | Installation location
Please provide the location where the Intel Fortran Compiler Professional
Edition for Linux* version 11.1 will be installed.
1. Install in the "/opt/intel/Compiler/11.1/075" directory [default]
2. Specify a custom installation directory
h. Help
b. Back to the previous menu
q. Quit
Please type a selection or press "Enter" to accept default choice [1]: 2
/usr/local/intel
Checking the prerequisites. It can take several minutes. Please wait...
........../install.sh: line 516: 23749 Segmentation fault (core dumped) $pset_engine_binary --tmp-dir=$user_tmp --log-file=$log_file $silent_params $duplicate_params $params --PACKAGE_DIR=$fullpath
