select character type
Blane_J_
Here is the situation: I use unlimited polymorphic variable as dummy argument and in select section, how can I select character type with specified length(assume length 1) ? I've tried:
SELECT TYPE(var)
TYPE IS(CHARACTER(1))
TYPE IS(CHARACTER*1)
TYPE IS(CHARACTER(LEN=1))
END SELECT
But none of the above is correct. and only TYPE IS(CHARACTER(*)) can pass the compilation. Appreciate anyone can show me an example.
Xiaoping_D_Intel
It has been written in the compiler documentation "SELECT TYPE" description:
type
Is an intrinsic type specifier or a derived-type specifier. It must specify that each length type parameter is assumed. It cannot be a sequence derived type or a type with the BIND attribute
So only ""CHARACTER(*)" will be accepted by the compiler.
Xiaoping Duan
Intel Customer Support
Xiaoping_D_Intel
type
Xiaoping Duan
Blane_J_
Oh, I see. Than additional tests should be made within TYPE IS block, thanks Xiaoping.
