29487 Discussions
sequence dependences of static libs on ifort command line?
woshiwuxin
Hi, everyone!
Suppose we have three different static libs, namely one.a, two.a, three.a.
If the executable is linked as the command below:
[bash]ifort -o main one.a two.a three.a[/bash]
It may not work. However, if I change the sequence of the statlic libraries on the command line, e.g.
[bash]ifort -o main three.a one.a two.a[/bash]
It would work.
So, here is my question. Is there a sequence dependence of static libs on ifort command line?
The list of libraries you specify is just passed to ld as-is. ld may not go back to an earlier library if a later one adds a reference to a routine in an earlier library. You may want to add the set of libraries twice to the command line.
TimP
For recent versions of gnu ld, you may pass the group directives from the compiler, e.g.
-Wl,--start-group *.a -Wl,--end-group
so as to request re-scanning for circular dependencies among those .a files.
The MKL documentation includes examples of this.
