Hi, so I've been struggling with what seems to be a general documented bug in SETWINDOWCONFIG, but I've never seen this particular version. It began with getting a "integer divide by zero" deep in a subroutine called by SETWINDOWCONFIG. This alerted me to the fact that, despite the documentation, doing a SECOND or THIRD call to SETWINDOWCONFIG after a first failure didn't fix things. In fact, I found that it can be called 100 times without anything changing.
Now the biggest puzzle is that when I am debugging this under Microsoft Visual Studio, I still get the FALSE reply for the call, but if I bravely go on, nothing terrible happens. But when the program is run by itself, this leads to the screen disappearing (the window is infinitely small)--for some reason, I no longer get the 'divide by zero' problem, though this also only happened out of the debugger.
Does this make any sense to anyone?
Thanks!
-john
the basic code in this subroutine is...
USE IFQWIN
Real*8 version
INTEGER*2 dummy, fails
LOGICAL STATUS, WAITFOR, ERROR
CHARACTER*9 namever
CHARACTER*4 Name
TYPE (windowconfig) wc
IF(WAITFOR) THEN
READ (*,'(A)') namever
ENDIF
fails = 0
wc%numtextrows=-1
wc%numtextcols=-1
wc%mode = QWIN$SCROLLDOWN
namever(1:4)=Name
Namever(5:5)=' '
Write(namever(6:9),'(F4.2)') version
wc%title=namever
STATUS=SETWINDOWCONFIG(wc)
DO WHILE (.NOT. STATUS)
Write(1,*)'At least one setwindowconfig failure....'
fails = fails + 1
IF (fails.GT.99) THEN
CALL ERRMESS(249, ERROR)
EXIT
END IF
STATUS=Setwindowconfig(wc)
END DO
IF (.NOT. ERROR) dummy=DISPLAYCURSOR($gcursoron)
RETURN
END
Thanks!
-john
USE IFQWIN
Real*8 version
CHARACTER*9 namever
CHARACTER*4 Name
IF(WAITFOR) THEN
ENDIF
fails = 0
wc%numtextrows=-1
wc%numtextcols=-1
namever(1:4)=Name
Namever(5:5)=' '
wc%title=namever
fails = fails + 1
EXIT
END IF
END DO
RETURN
END
The one thing that I noticed is that the title needs to be a C string.
That is, it must be null terminated, and yours is not.
Try making namever 10 characters long, and setting the final character as a zero.
You can do this with
namever(10:10) = char(0)
-- Lorri
-- Lorri
