29657 Discussions
showing error in using DGEEV function
Rohit8199
I am developing the FORTRAN code for my project in which I need to use the DGEEV function, but while debugging the compiler shows an error. It would be helpful if you suggest to me what to do. I am writting the error message shown and the settings so that you can tell me what mistake I have done.
Error: Severity Code Description Project File Line Suppression State
Error error LNK2019: unresolved external symbol DGEEV referenced in function DGEEV.t2903p.t2904p.t2905p.t2906p.t2907p.t2908p.t2909p.t2910p.t2911p.t2912p.t2913p.t2914p.t2915p.t2916p.t3v.t3v SLJ2.obj
Screenshot 2024-01-23 130740.pngScreenshot 2024-01-23 130818.pngScreenshot 2024-01-23 130856.pngScreenshot 2024-01-23 130948.png
Mark_Lewy
Valued Contributor I
Have you set your project to use the MKL library (as above)?
Mark_Lewy
Rohit8199
This was helpful. Thank you!
