simple dialogue control question
chunky_lover_23
Does anyone know a simple way to hide or otherwise make invisible a control (eg a combobox) item within a dialogue panel ?
Jugoslav_Dujic
Valued Contributor II
Statically (from the dialog editor): uncheck the "Visible" check box.
Dynamically (from the code):
USE DFWIN
ShowWindow(GetDlgItem(Dlg%hWnd, IDC_COMBO1), SW_SHOW/SW_HIDE)
This will work only while the dialog is active (i.e. after DlgModal or DlgModeless, not before), that is, from callback routines. To initialize a control to non-default-visible state, you have to do it from a dialog-initialization callback (DLG_INIT)
You might also be interested in this.
