29434 Discussions
Can 64bit fortran code call 32 bit library routines?
randystonesifer
We need large arrays so we need 64 bit fortran code. We have been using the 32 bit metis library (C code supplied as a Windows library) and it appears large arrays may not be an issue for these library routines. Can we use the 32 bit library while creating a 64 bit fortran .exe?
TimP
No, all .obj must have matching /machine tags. If you bypass that check some way, your .exe will hang at run time.
randystonesifer
That is what I was going to assume, but thought it was worth confirming.
randystonesifer
I supposethat a DLL mustalso be 64 bit to be called by a 64 bit program?
Correct.
