We need large arrays so we need 64 bit fortran code. We have been using the 32 bit metis library (C code supplied as a Windows library) and it appears large arrays may not be an issue for these library routines. Can we use the 32 bit library while creating a 64 bit fortran .exe?
No, all .obj must have matching /machine tags. If you bypass that check some way, your .exe will hang at run time.
That is what I was going to assume, but thought it was worth confirming.
I supposethat a DLL mustalso be 64 bit to be called by a 64 bit program?
Correct.
![](/skins/images/76FBCD0056552B7B74FE0D35ED948B09/responsive_peak/images/icon_anonymous_message.png)
Topic Options
