[solved] [maybe OT] FFTW + OpenMP3 + ifort
Alexis_R_
I apologize if this is off-topic - it could be that this is an fftw-related issue. Still, this may benefit other ifort users.
The following test program runs without errors when OMP_NUM_THREADS == 1, but aborts when multiple threads are used (with "fftw: alloc.c:187: assertion failed [...]"). The program also gives expected results when DIM = (/256,256,256/), even with multiple threads.
This is with ifort 11.1.069, fftw 3.2.2 (configured with --enable-shared --enable-float --enable-openmp --enable-debug and built with gcc 4.4.3).
[fortran]MODULE FFTW_INCLUDE
INTEGER FFTW_MEASURE
PARAMETER (FFTW_MEASURE=0)
INTEGER FFTW_UNALIGNED
PARAMETER (FFTW_UNALIGNED=2)
INTEGER FFTW_ESTIMATE
PARAMETER (FFTW_ESTIMATE=64)
END MODULE FFTW_INCLUDE
PROGRAM FFTW_OPENMP_TEST
USE FFTW_INCLUDE
USE OMP_LIB
IMPLICIT NONE
! VARIABLES
INTEGER :: I
REAL, ALLOCATABLE :: RARRAY(:,:,:)
COMPLEX, ALLOCATABLE :: CARRAY(:,:,:)
INTEGER(KIND=8) :: PLAN
INTEGER :: DIM(3)
! START WORK
DIM = (/254,254,254/)
!$OMP PARALLEL PRIVATE(RARRAY,CARRAY,I,PLAN) SHARED(DIM)
ALLOCATE(RARRAY(DIM(1)+2,DIM(2),DIM(3)),CARRAY(DIM(1)/2+1,DIM(2),DIM(3)))
!$OMP SINGLE
CALL SFFTW_PLAN_DFT_R2C_3D(PLAN, DIM(1), DIM(2), DIM(3), RARRAY, CARRAY, FFTW_ESTIMATE, FFTW_UNALIGNED )
print '(a,i1)', '**debug(): planning done for thread ', omp_get_thread_num()+1
!$OMP END SINGLE COPYPRIVATE(PLAN)
print '(a,i1,a,i)', '**debug(): about to start do loop on thread ', omp_get_thread_num()+1, ' with plan ', plan
!$OMP DO
DO I=1,4
CALL SFFTW_EXECUTE_DFT_R2C(PLAN,RARRAY,CARRAY)
!PRINT '(A,I1,A,I1)', '**DEBUG(): THREAD', OMP_GET_THREAD_NUM()+1, ' JUST FINISHED ITERATION ', I
ENDDO
!$OMP END DO
!$OMP END PARALLEL
END PROGRAM
[/fortran]
The compile & linking line I use is:
[bash]ifort -L/where/fftw/is -O0 -openmp -static test.f90 -lfftw3f[/bash]
And this is what I see when I run it with OMP_NUM_THREADS = 4:
[bash]**debug(): planning done for thread 1
**debug(): about to start do loop on thread 1 with plan 46912652832512
**debug(): about to start do loop on thread 3 with plan 46912652832512
**debug(): about to start do loop on thread 4 with plan 46912652832512
fftw: alloc.c:187: assertion failed: (stat->cnt == 0 && stat->siz == 0) || (stat->cnt > 0 && stat->siz > 0)
Abort[/bash]
Any pointers as to what is going on would be much appreciated. Again, I apologise that this is OT for this forum.
Alexis_R_
Steven G. Johnson has pointed out to me that the flag --enable-debug-malloc is not threadsafe and is meant for development use only. Removing "--enable-debug" from the configure options when building fftw solved my problem.
So this really wasn't anything to do with ifort.
