some variables can not be watched
Wang_J_
     when i debug a program with VS2008 and Intel.Visual.Fortran.Compiler.Professional.v11.0.061 , i set a break point, and then watch the value of some variables. These variables were declared in module, and they were used in other modules. Parts of them can be watched but some of them were displayed as "undefined variable".  Is this a bug? How can i deal with this problem?
You're using a very old version of the compiler - we have made many improvements in debugging since then. If you can attach a small example (a ZIP of a project would be best), I'd be glad to try it out in the current version.
Wang_J_
Is this version of fortran "Intel.Visual.Fortran.Compiler.Professional.v11.0.061" can work with vs2010?  When i use vs2008 the fortran compiler can be found automatically. But if I install vs2010 and then install fortran it can not be found.
My code is too long. if i just post parts of it , it can not work.
No, Fortran 11.1 does not support VS2010. The current version (Intel Visual Fortran Composer XE 2013) does.
