29280 Discussions
sorting, random numbers and Edition 6.6
Anonymous42
I have "Compaq Visual Fortran Standard Edition6.6".
I wantto use random number generator inCXML. How can I get it? I get the following error message:
Cannot open include file 'CXML_INCLUDE.F90'
I'm also searching for some fast algorithm to sortmatrix of higher dimension by aspecified column.Does Intel Fortran contain any build-in routine capable of this? I will veryappreciate any advice or links.
Only for these two reasons, wouldyou recommend metoupdate to Intel Fortran?
Thank you for your help,
Milan
Steven_L_Intel1
I think CXML is an optional feature when you install. You can just copy the CXML folder off of the CD into the "DF98" folder on your hard disk. Be sure to add the CXML/INCLUDE and CXML/LIB folders to your include and library directory lists.
Intel Fortran doesn't include sort routines, other than the general QSORT which you can extend with a user comparison routine.
Anonymous42
It works now, I just had to add it to the directory lists. Thank you very much.
Jugoslav_Dujic
Valued Contributor II
Re sorting, Google for ORDERPACK.
Jugoslav
