stack overflow problem
mybiandou
Hello, I found a strange problem when I use Intel Fortran
Intel(R) Fortran Intel(R) 64 Compiler Classic for applications running on Intel(R) 64, Version 2021.10.0 Build 20230609_000000
The minimal work source code is as the below,
subroutine foo(adim1,bdim1,adim2,bdim2,a,b,abdist)
    implicit none
    integer,parameter::nmax=1000
    integer ,intent(in):: adim1,bdim1,adim2,bdim2
    double precision ,intent(in)::a(adim1,adim2),b(bdim1,bdim2)
    double precision ,intent(out)::abdist(adim2,bdim2)
    double precision :: c(nmax,nmax)   !OK
    !double precision :: c(adim2,bdim2)     !NG
    print*,"adim1,bdim1,adim2,bdim2:",adim1,bdim1,adim2,bdim2
    c=0.0
    abdist=0.0
    return
end subroutine
program main
    implicit none
    integer,parameter::nmax=1000,ndim=2
    integer na,nb
    double precision a(ndim,nmax),b(ndim,nmax)
    integer i
    double precision abdist_(nmax,nmax)
    double precision ,allocatable :: abdist(:,:)
    print*,'test:'
    !OK case
    na = 500 ;  nb = 250    !(1)
    ! NG case
    na = 500 ;  nb = 300    !(2)
    do i=1,na
      a(:,i) = i*1.0
    end do
    do i=1,nb
      b(:,i) = i*1.0
    end do
    !reshape abdist according to the current size
    abdist = RESHAPE(abdist_,(/na,nb/))
    call foo(ndim,ndim,na,nb,a ,b,abdist)
    print*,"final abdist:",abdist(na,nb)
    stop
end
In the subroutine foo, if I declare array c
Then, in my test main program,
when I let na=500;nb=250, it is OK.
But when I let na=500;nb=300, it gave me error.
forrtl: severe (170): Program Exception - stack overflow
But if I declare c in subroutine foo as
double precision :: c(nmax,nmax)  !nmax=1000
it will also be OK.
I compile the above code using command
ifort test.f90 -check -traceback  -o test.exe
gfortran has no such problems.
Please help me to solve this problem. Thank you in advance.
andrew_4619
You are exceeding the stack size. There are compiler options to change the stack size and also the heaparrays option to make certain things be created on heap rather than stack. it gets a bit complicated and is effort! As a principal it is usually better to make larger arrays allocatable and allocate them and they are then always on the heap.   See if that fixes the problem.
Steve_Lionel
gfortran uses the equivalent of Intel's -heap-arrays option by default.
mybiandou
Thanks for your answers, andrew_461 and Steve_Lionel.
Following your help, I use -heap-arrays option and get it run ok.
ifort test.f90 -heap-arrays  -check -traceback  -o test.exe
