stack overflow
antfu
Dear all,
I wonder how I can increase the stack size in my Intel Fortran 11.1 professional ?
First suggestion is to set the project property Fortran > Optimization > Heap Arrays to 0 (zero).
If that doesn't help, then the stack size is set by property Linker > System > Stack Reserve Size. The default is 1000000 (one million bytes), so start with 100,000,000 and see where that gets you.
TimP
The primary stack size is controlled by Visual Studio options such as /link /stack: and the corresponding options in Visual Studio project linker properties (or by editbin ....). If you are using /Qopenmp or /Qparallel, there is also per thread stack, for which you would look up kmp_stacksize.
antfu
Thanks for your reply and instruction. I will try that .
