submodules
Blane_J_
There is a compilation issue occured when circular reference is employed. See the codes:
module test1
    implicit none
    integer, parameter :: a = 5
    interface
        module subroutine sub1()
        end subroutine sub1
    end interface
end module test1
submodule(test1) submodule1
    use test2
    implicit none
    contains
    module procedure sub1
        implicit none
        print*, b
    end procedure sub1
end submodule submodule1
module test2
    implicit none
    integer, parameter :: b = 4
    interface
        module subroutine sub2()
        end subroutine sub2
    end interface
end module test2
submodule(test2) submodule2
    use test1
    implicit none
    contains
    module procedure sub2
        implicit none
        print*, a
    end procedure sub2
end submodule submodule2
program main
    use test1
    use test2
    !TO DO.
end program main
The use association in submodules are permitted by the standard. An error shows up when compile for the first time:
error #7002: Error in opening the compiled module file.  Check INCLUDE paths.   [TEST2]
If then we compile it again without cleanning-up, the target assembly will be created successfully. So is it a compiler mistake ? Or how should I do to solve it ?
andrew_4619
Blane J. wrote:
Yes Andrew, they are all in the same file, separate case gives the same result.
In the same file is a certain fail, and would be a bit daft as the whole point of submodules is to separate the interface from the implimentation to avoid build cascades.  You are forcing things to be all recompiled.
andrew_4619
Are they all in the same file?
Blane_J_
andrew_4619
1>------ Build started: Project: blane_test, Configuration: Debug Win32 ------
1>Compiling with Intel(R) Visual Fortran Compiler 18.0.0.124 [IA-32]...
1>Source2.f90
1>Source4.f90
1>Source3.f90
1>Source5.f90
1>Source1.f90
1>Linking...
1>Embedding manifest...
1>
1>Build log written to  "file://C:\Users\....\blane_test\Debug\BuildLog.htm"
1>blane_test - 0 error(s), 0 warning(s)
========== Build: 1 succeeded, 0 failed, 0 up-to-date, 0 skipped ==========
It works OK for me
andrew_4619
Blane_J_
Yes, I then splited those entities each into different files and had the same result as you did, previously I only isolate the main program from the modules and submodules. Thanks Andrew.
