subroutine building error
keremusu1
Hello!
I would like to build an executable file (*.exe)by using the subroutine below.
subroutine hypela(d,g,e,de,s,temp,dtemp,ngens,n,nn,kc,mats,ndi,nshear)
implicit real*8 (a-h,o-z)
include '/msc/marc2003/common/concom'
dimension e(1),de(1),temp(1),dtemp(1),g(1),d(ngens,ngens),s(1)
dimension n(2)
if (ncycle.eq.0) epsend=e(1)
if (ncycle.gt.0) epsend=e(1)+de(1)
c1=1.0d0
c2=2.0d4
d(1,1)=c1+2.0d0*c2*epsend
s(1)=c1*epsend+c2*epsend*epsend
return
end
When I build the solution, I see the following errors:
Error1 error LNK2019: unresolved external symbol _MAIN__ referenced in function _mainlibifcoremt.lib
Error2 fatal error LNK1120: 1 unresolved externalsDebugConsole6.exe
Does anyone have an idea about what theproblem can be?
Thanks!
You cannot build an executable from just a subroutine - you need a main program which calls the subroutine, passing it the necessary data.
You can build a DLL if you want which can then be used by a separately compiled program. Read the on-disk documentation for information on building libraries and DLLs.
